Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
beware accel opti
Old Apr 19, 2007 | 04:39 PM
nick3's Avatar
beware accel opti
i had it go out twice now and finally found out why. the shaft on the accel is an 1/8 inch longer then the stock opti. the cam was puting the pressure on it and causing the rotor button to heat up against the cap and bust. i will not buy one again
Old May 28, 2007 | 11:23 PM
Dan Parker '96's Avatar
I've been running one for several thousand miles and 7K+ rpm (albeit connected to a Delteq). Hasn't blown up yet.
Old May 29, 2007 | 07:55 AM
2000GTP's Avatar
That is a pretty sizable difference.
Old May 31, 2007 | 01:45 PM
dannyum89's Avatar
I noticed that too when I was trying to install one on a buddies car. I could barely get the opti housing to touch the timming cover. Sent it back quick.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
