Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Hole in the fuel __nk!
Old Apr 8, 2007 | 09:59 PM
jons69's Avatar
Pulled the camaro out of storage and found a puddle of gas all over the floor. After inspection an obvious hole was found on the bottom of the tank. I have a new one on the way after some backordered parts come in. My question though is I only drive the car occasionaly (once every 3 months) and a couple of months to this leak, I found numerous particles in the fuel filter. Do I need to replace the fuel lines or is the tank all I need to do.
Old Apr 8, 2007 | 10:28 PM
Might want to add some basic info, like the year of the car, model, engine, etc.
Old Apr 9, 2007 | 02:21 PM
transAMdriv3r's Avatar
may only need to do the tank, the fuel filter should have stopped the particles, but remeber this...the dirt had to pass through the fuel pump to get to the fuel filter so i would check and make sure you dont have to replace that before you put it back together agian. might as well just do a new fuel pump while your at it.
Old Apr 11, 2007 | 10:42 PM
jons69's Avatar
Good idea about the fuel pump, that never would have crossed my mind! By the way this is on a 1969 camaro w/350, stock tank, stock fuel pump, stock lines,ect.
Old Apr 12, 2007 | 09:27 AM
OBE1 95Z28's Avatar
The fuel pump has a filter sock on it's inlet. Still a good idea to replace the pump and filter sock since the tank is being replaced.
Old Apr 12, 2007 | 10:39 AM
MEAN LT1's Avatar
I think he has a mechanical pump if he running a 69?.
Old Apr 12, 2007 | 10:30 PM
jons69's Avatar
Mechanical
It is a mechanical fuel pump! Should I still replace it?
Old Apr 12, 2007 | 10:41 PM
jons69's Avatar
I've always wanted to replace the stock mechanical pump with a Edelbrock or a Holley high performance mechanical fuel pump, but they would never fit.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
beltrunner
Apr 15, 2015 01:10 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
