Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need help finding the right spark plug between these two...
Old May 16, 2007 | 11:21 PM
CALL911's Avatar
I am running 15#'s of boost (+ or - a few #'s) on my 383 LT1 in my sig. Which Autolite plugs should I be running between the Autolite 3923, and the Autolite 3922? It should be the same heat range as the Autolite 103 but I can't find out which I need. I need the gasketed plug as I have AFR 180 heads.
Can anyone help me out here? I need to find out which I should run between the two ASAP.
Old May 17, 2007 | 07:08 PM
deadcamaroz28's Avatar
Autolite AR50 are one colder than stock they are for afr heads that need the gasket
I dunno if that helps
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
