Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Injector Circuit(s)
Old May 3, 2007 | 12:31 PM
S2K at 9K's Avatar
Injector Circuit(s)
Over the last couple weeks, my car has had an occasional weak ignition start. And on a couple rare occasions, I had to give a little gas while starting up my car. Well today, I had to give a little gas while starting my car. I looked at my Scanmaster LT1, and it picked up a diagnostic trouble code. I looked up the code and all it says is "Injector Circuit(s)". What exactly can the problem be? I'm guessing it is more of an electrical problem than a mechanical problem? Any help would be great.
Old May 3, 2007 | 06:16 PM
The PCM looks at the voltage on the injector circuits, and sets a code if the voltage isn't where its supposed to be. Could be failure of the +12V supply to the injector, failure of the injecotr's electrical coil, or failure of the ground provided by the PCM.
Check for +12V at the pink wire at each injector harness clip. Check the resistance of each injector (12-16ohms). Use a "noid" light to verify the PCM ground is reaching the injector.
"Giving it a little gas" doesn't really do much at startup, other than allowing a bit of extra air into the engine. If you put the pedal on the floor, while cranking, it puts the PCM in "clear flood" mode, and significantly reduce injector flow to clear a flooded condition.
Old May 6, 2007 | 12:55 PM
S2K at 9K's Avatar
The problem seems to be fixed. I think that the injectors just had some build-up of some kind in them.
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
