Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
30# injectors enough?
Old Mar 17, 2007 | 03:01 PM
maro z28's Avatar
Can 30# SVO injectors properly supply fuel for this cam:236/242 .624/.576 110+4?
Looking to spin up to the low to mid 6k range. Injectors are backed by Racetronix fuel system and adj. fuel pressure regulator. Thanks!
Old Mar 17, 2007 | 03:16 PM
Spitfire557's Avatar
I'd go for the 36# injectors with a cam that size, but my opinion isn't backed by much experience, so I'd wait for someone else to chime in also!
Old Mar 17, 2007 | 04:47 PM
maro z28's Avatar
Which LE set up do you have? LE1? LE2? LE3? What size injectors do you have? Just curious?
Old Mar 22, 2007 | 02:20 PM
jsetzer's Avatar
Thats a crapload of intake lift compared to the other numbers. I ran a 306 on stock injectors. 30 should be plenty.
Also you have an adjustable if you need a little extra help too.
If you are buying new, get bigger to be safer for the future. If you found a great deal take the 30s.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
