Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What Ignition Components are worth upgrading?
Old Mar 20, 2007 | 10:20 AM
1LESSZ28's Avatar
budget minded so nothing extravagant. just wondering if there are any benefits (mpg and/or hp) to more powerful coils, wires, ignition modules, msd 6a etc.
Old Mar 20, 2007 | 10:40 AM
2000GTP's Avatar
On a stock or bolt-on car, plugs and wires would be as far as I would go. I wouldn't replace the coil or ICM unless necessary and I wouldn't run an ignition box unless I had the engine mods to require one.
Old Mar 20, 2007 | 12:01 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Didn't the 93-95 models have a weaker coil? I believe I'm going to change my coil when I put a new opti on, but I'm not sure whether to get a Crane or MSD. Are those comparable quality? I think there is also one made by Hypertech.
Old Mar 20, 2007 | 12:40 PM
1LESSZ28's Avatar
Yes, the 96-97 coil is better not sure if it is plug and play though on later models (maybe other parts were upgraded on 96-97 years?).
Old Mar 20, 2007 | 12:47 PM
canuck94z28's Avatar
Msd 6a
I got a little better drivability and slightly better throttle response w/mine.BTW try find one used as their not worth the new price.
Old Sep 29, 2007 | 07:55 PM
stopthatman's Avatar
Has anyone upgraded to the 96 coil/ICM on a 94? plug n play?
Old Sep 30, 2007 | 09:24 PM
blueformula350's Avatar
It isnt plug and play. The plug is a different style (still 3 wire) you can order the correct plug from gm (part no. 88987992) and splice it into the harness. You also need a coil wire from a 96+ LT1.
Old Oct 1, 2007 | 01:59 AM
thanks, but damn i don't want to splice the wires. crap
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Feb 22, 2015 11:16 AM
CARiD
Jan 27, 2015 06:27 AM
