Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Is this possible on my 96 camaro?
Old Mar 14, 2007 | 11:04 AM
Mike96z's Avatar
My fuel pump just went out I think, car just died and wont start up, coil is sparking, checked it. Fixin to check fuel pump. Would this fuel pump work?
http://www.jegs.com/webapp/wcs/store...0002_750073_-1
Aeromotive A1000, I know its not intank but its inline, could I possibly put it in the fuel line before the fuel filter and just run it like that without messin with the intank or would I have to remove the intank, is this possible without a fuel cell?
Old Mar 14, 2007 | 11:22 AM
afr lt1's Avatar
you can make sure its the fuel pump by just turning the key to the on position and listen for the fuel pump to turn on.
Old Mar 15, 2007 | 10:59 PM
You can't put an inline pump into a system with a dead in tank pump.... won't work. The dead in tank pump would kill the suction to the inline pump.
I'd check the fuel pressure before jumping to the conclusion that its the fuel pump. Might also want to check the PCM for codes, since a problem with the low resolution pulse from the Opti will cause the PCM to shut down the fuel system.
Old Mar 16, 2007 | 01:02 PM
zlighting's Avatar
Try to fix your problem with a logical Approach
  • Check your Ignition and PCM fuses.
  • Check for Service Codes.
  • Check your fuel Pressure.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
