Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Plugs and wires
Old May 30, 2007 | 11:49 AM
speed76demon's Avatar
Plugs and wires
I am going to replace my plugs and wires, and I was wondering what wires you guys would recommend? And how long do you think it will take to replace? I do not have headers, so I believe it will be tougher.
Old May 30, 2007 | 11:55 AM
2000GTP's Avatar
For wires, I have always been happy with the Taylor sets. Also, MSD and even another set of stock Delco wires will work well. As for plugs, I like using the NGK plugs, but again, another stock Delco set will do the job. As for the actual procedure, it will easily take you several hours I'm sure.
Old May 30, 2007 | 12:58 PM
streetracerx's Avatar
not to jack a thread or anything, but is it worth doing plug wires if mine are still the stock ones with 150k, i just installed new plugs
Old May 30, 2007 | 01:16 PM
2000GTP's Avatar
With that kind of mileage on stock wires, I would say they are due for replacement.
Old May 30, 2007 | 01:48 PM
ya i figured as much, do you think it will make much of a difference?
Old May 30, 2007 | 03:16 PM
2000GTP's Avatar
If the wires are to the point where they are causing a power loss, then you will simply recoup what you have been losing. The wires themselves will not create power gains.
Old Jun 3, 2007 | 05:09 AM
IdahoLT1's Avatar
Are you sure they are the original wires? I would imagine after 13 years and 150k miles they would be in real, real bad shape. I did my wires because they were almost burned in half and the rubber insulation was cracking and falling off. 4 of the wires i pulled off were still in good shape and looked like the new ones just dirtier.
Old Jun 3, 2007 | 05:12 AM
IdahoLT1's Avatar
Taylor wires and NGK plugs is what i used. As far as time, it depends on your mechanical ability. On the books its listed as a 4-6 hour job for a repair shop. I would set aside atleast a day, just to be on the safe side.
Old Jun 15, 2007 | 06:33 PM
Do you think I should replace my coil as well? If so, what coil do you recommend? Thanks for the help
Old Jun 15, 2007 | 07:47 PM
2000GTP's Avatar
If your current coil isn't causing you any issues, then you should be fine. However, considering that coils are relatively inexpensive, you could always replace it for good measure. Another stock Delco would work or you can go with an aftermarket alternative like MSD.
Old Jun 15, 2007 | 08:41 PM
Do you know the part number for the MSD coil?
Old Jun 16, 2007 | 02:35 PM
2000GTP's Avatar
93-95= 8226
96-97= 8231
Old Jun 16, 2007 | 05:07 PM
Thanks for all your help
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
