Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
opti
Old May 17, 2007 | 10:11 PM
Mikek340's Avatar
opti
Could you use a non-vented opti on a 96 camaro?
Old May 18, 2007 | 08:44 AM
SloLt1Z's Avatar
Yeah, but there's no point they are even crappier
Old May 18, 2007 | 09:22 AM
Only if you swapped out the cam sprocket, swapped out the timing cover, eliminated the CKP sensor (program out of PCM), swapped the short Opti harness, shortened the cam dowel pin and plugged the holes in the intake elbow and the vacuum connection on the side of the intake manifold.
Then you would be left with an Opti that is more prone to degradation due to ozone, and would not be as likely to dry out if it got damp.
Old May 18, 2007 | 07:33 PM
Mikek340's Avatar
Alright thanks
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
