Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
lithium on injectors?
Old Apr 22, 2007 | 12:25 PM
LenT1's Avatar
Im about to install new injectors and this book I have says to put lithium grease on them before install. Does it go on both o-rings or what?
Thanks in advance.
Old Apr 22, 2007 | 01:13 PM
Its a good idea to put a little lubricant on the O-rings to avoid damage as they slide into the holes. But I've never heard of using lithium grease. What is the reference book?
Old Apr 22, 2007 | 01:18 PM
LenT1's Avatar
HPBooks "How to Rebuild Small-Block Chevy LT-1 / LT-4 Engines"
Old Apr 22, 2007 | 01:51 PM
Never noticed that one.... Chilton's says to use clean motor oil. That's all I've ever used.
Old Apr 22, 2007 | 02:24 PM
LenT1's Avatar
Appreciate it, that sounds more safe to me
Old Apr 23, 2007 | 12:06 PM
JSK333's Avatar
You could also use an engine lube such as Seafoam DeepCreep.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
