Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
warning: optispark!
Old Apr 23, 2007 | 09:47 PM
lt1 beast's Avatar
warning: optispark!
I was about read to throw my jack throught the winsheild of my car! ive had the motor apart so many times and i checked the timing numerous amounts of times. I finally got it running thank god! Just to save you guys headaces check to make sure your cam dowel pin is in the notched part of the distributor because it will still fit if it is off....a sure fire way to tell if your timing is off is a coughing or backfire out the intake.
Old Apr 23, 2007 | 10:17 PM
aifilaw's Avatar
that's a DUH....
there's probably more posts about that than anything else on the forums.
Old Apr 24, 2007 | 09:22 PM
lt1 beast's Avatar
haha...nd ill never make that mistake again
Old Apr 24, 2007 | 10:24 PM
bombebomb's Avatar
Shoulda asked I coulda told you that (if you did ask sorry for my blindness) Also make sure the pin is the correct lenght (if aftermarket cam).
Old Apr 24, 2007 | 11:20 PM
seawolf06's Avatar
Also good to triple check that your plug wires are routed correctly. I had that problem for a while.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
