View Full Version : Classic Engine Tech
Pages :
10
11
12]
13
- heads?
- Looking for a first gen
- T56 Clutch master stroke?
- Anyone wanna trade cars?
- Will 4th Gen Rims fit on a 2nd Gen?
- What size is this carb?
- Backspacing on a 69 Camaro.
- Rearend swap
- fattest wheels that can fit
- need some timing advice
- RS Headlight conversion
- 400ci and 350ci
- Powerglide
- putting 68 traction bars on '68 camaro
- 400 Small Block
- Ind. Suspension in a 1st Gen?
- BB ram jet
- which year of 400 small blocks are better?
- Anyone with older Convertables in here!!
- question on th400
- Carburetors
- Flexplate teeth?
- LS6 compatibility
- need some wheel help
- 69 camaro turn lights
- rich holley!
- At the strip again
- Replacing Quadrajet Carb on 69
- engines
- What is the weight of a stock 67 Camaro?
- 400 Head Gasket ID, need HELP ASAP!!!! PLEASE!
- Exhaust Question
- LT-1 Into a 87 Buick Regal? How Hard?
- Ideas on next motor ....
- lowering a 1980 Z28
- One Wire Alternator Install
- Wheelhop, traction bars, and crappy springs
- What should I expect?
- Control Arm Bushings
- taking out radio
- Which gears to run?
- help id a block #
- leaf springs
- Roots supercharger on 454
- smog pumps
- Holley carb identification
- Distributors - MSD - Says it will only work with their complete ign. system?
- Muncie M21, M22, or Super T10 for my 69 Camaro
- mufler question
- Holley Blue Electric fuel pump...
- Wow...
- CPP disc brake conversion kit?
- springs
- biggest tires on a 15x8 corvette rallye wheel?
- battery dead
- Quick question regarding Holley Carbs
- What is the maxium amount of lift you can run with 6X pontiac heads.
- Strength of the corporate 10 bolt rear
- My first camaro question
- Need Help Choosing new intake
- Question = What is the difference between Total timing and initial timing?
- how to change pontiac ignition switch
- Does anyone know Greg McGann?? (http://www.holisticpage.com/camaro)
- 327cui
- Baby steps.
- 327cui vs 350cui
- stereo placement
- 2nd gen suspension recc.
- stock heads/dome pistons
- Wanted:Pic of a 1st Gen w/ exhaust ....
- Engine Block ID
- Please explain the difference between solid and hydraulic lifters.
- anyone here using a vac. reserve cannister?
- can't time 67 camaro 350
- Vette
- Scrap Old plans, new monster!!!
- Stock 305 head numbers: what can you tell me
- 67 option question
- Would a .060 455 with High Domes and a nice cam be a decent starting set up?
- ANY aftermarket/new/rebuilt 4 speeds for BOP engines??? T-10???
- connecting rods
- I have a serious question
- Steering quiestion
- Rear Disc for my 68 10 bolt rearend
- Vortec Heads on 68 327
- Approx HP from my 305? please give me your best approximation
- 68 Camaro rolling chassis
- Subframe connectors?
- Engines and parts....
- T56 In 69 Camaro
- Easy way to test rings with heads off?
- FS: 1967 Camaro RS/SS GM 502ci + Holley Supercharger + NX
- help!!!
- Oil leaking out of intake bolts....
- Project car Finally Makes It to the Track!!
- Anyone that knows anything about the yenko Turbo Z's please read
- Can I supercharge my 69 Camaro?
- what times to expect?
- First Generation Camaros
- HELP!!!-Vibration at 4000 rpm an higher
- LT -75 rear
- Cylinder pressure
- rocker arms
- I have a 73 camaro engine where is my voltage regulator?
- classic t/a dis.
- TCI Street Fighter TH350 FOR SALE
- cutouts / exhaust dumps / open headers
- wire short for tail light /parking lights
- fuel delivery question
- Information Board
- ET STREETS FOR SALE
- vortec heads
- '78 Trans AM?
- Qjet Choke on Vortec Manifold?
- 1977 chevy 350
- tire size for 67 bird
- Head castings
- LPW Rearend Support Cover for 8.2 or 8.5 Rearend and Cragar Superlites for sale!
- cruise control
- mild perf cam for a stock 454
- double hump intake port size?????
- 2 original '79 Z hoods 4 sale...
- Firewall painting...
- Neutral Safety Switch
- Push Rods
- Will a bigblock fit a 78?
- rear shock relocation and 17X9.5 wheels on a 67 ?'s
- REAR END WENT OUT IN MY CAMARO!
- stock aluminum intakes... r they n e good
- How many hp?
- What happened to the Camaro Research website?
- Is this '68 SS396 a good deal? Help ASAP!!!!!
- need help pontiac 400
- Vapor lock
- Insurance costs for older camaros
- Where to buy engine block?
- water pump suggestions...
- Need a recipe for a 455.
- Disc Brakes
- SBC 350 and TH350 for sale!!!
- Is this 78 camaro worth 850?
- Crane Gold Roller rockers for sale>>
- 2 BBC flywheels for sale (both new)>>
- Why the overheating on my '79?
- slicks
- Turbo 350
- T-5 in 72 Camaro?
- Is my BBC a freak?
- Poncho engine help needed
- Need pricing for 350 forging?
- 70's 350's
- a Good 383 kit?
- differential cover bolt torque specs?
- 72 455 Trans-Am running 12.0's bone stock?
- 1/4 Est. for a 73 T/A?
- question for old school poncho guys
- 327 build up
- FS: 1968 Numbers Matching Camaro RS in MI
- first generation exhaust system for sale....
- Buy my TCI TH400 rebuild kit *NEW*
- What r ur MPG's for ur 60's-70 V-8?
- 10.5" clutch plate on big block >>
- How much boost could I run?
- Several Parts for sale........80 T/A
- Battery not charging, must be a short somewhere?
- Clicking noise from motor....
- Can a victor jr manifold be ported safely to fit a 1206 gasket?
- Help with dyno?
- Need help with suspension on 74 camaro LT
- 350 heads.....stock.. i guess
- sump/vaccum
- Project ended.....80 T/A.....owners inside....
- 77 Trans Am performance mods?
- what to do?
- Rear Gear Advice? 3.90 or 4.10?
- found a 68 convt camaro for sale, should i buy?
- HELP!!
- ur thoughts on a powertrax no-slip trac system??
- AFR 227's for SBC 408?
- Help!! Car is not running right??
- Just got new motor running today for the FIRST TIME!!!
- btw, how high can you rev a 403 w/ stock pistons,rods+crank?
- need new oil filter bracket for 403, where?
- 12-Bolt Troubles
- Speedometer
- car wont start
- 1979 Firebird Engine Help PLEASE
- 73' Camaro
- Help With Foot Brake?
- Need pictures of your 1970 Camaro!!
- need a black INTERIOR
- intake swap to low rise...power loss?
- a few questions
- Where to decode bog block serial number?
- How to wire alternator with Painless wiring kit?
- 1971 camaro pitman arm
- picked up some Dynomax Race Magnums
- cylinder heads opinion
- air cleaner height?
- long-tube headers - heated O2 sensor?
- OK, guys. Here's my questions.
- 68 Pontiac 400 Shortblock for sale
- LT1 Brackets Go bold or Beautiful?
- Cog Belt Pulleys?
- new mountain dew commercial
- BBC CSI water pump + LWP pulleys?
- Hardcore starting problems
- Good headers for 350 SBC?
- 50/50-Pictures-LAST UPDATE!
- Yenko Turbo Z
- emblems
- differences between 23 degree and 18 degree engines
- Wheel question
- Your challenge, should you choose to accept it
- Where can I find a 1980 front clip and hood for a Z28?
- 1974 camaro For Sale Or parts
- HELP!!!!! #5 plug wire fried and ran car on 7 cylinders for over an hour :(
- Is a 1969 X-66 code always a SS?
- Shocks
- Need Suggestions
- Not charging?
- 4th gen seats in a 1st gen?
- Vin Number
- winshield wipers
- B&M 144 SBC under 69Z28 hood?
- Question about muscle cars in general.
- Too much power for rearend?
- '68 camaro SS
- going to look at a 69 tomorrow...
- Tranny going into neutral at X rpm's
- Axle
- Rearend Help.
- 91 TPI 350 TRANSPLANTED INTO A FIRST GENERATION
- whats in my car!
- 68 Parts
- What posi and gears should i get?
- Usable components from 89 Firebird Formula?
- more rear end questions?
- Cam choice...
- Cooling Issues
- brakes
- Power out of a 283?
- Need to gain 1/2 second, all on motor! How?!
- Its finally running
- New car what to do with this one
- Your 350 water temp?
- Spark plugs and wires
- how do you build a vette/porsche eater?
- Swap Meet
