Help With Foot Brake?
Old Jul 23, 2002 | 12:39 PM
My Mighty White 95 Z28's Avatar
Post Help With Foot Brake?
Hey everybody, I just had a quick question. I have a 1980 Camaro 305 A3 TH350 and my question is when I push the foot brake down it goes all the way down and it seems it is not locking in or catching. Any suggestions or ideas what could I check? Thanks in advance for the help.
Eric Lelina
1995 Mighty-Whitey Z28
A4 3.23s,K&N FIPK,1LE intake elbow,Air Foil,!TB Bypass,Hypertech 160 Thermostat,Taylor Spiro-Pro Wires,Flowmaster Catback System,Eibach Pro Kit,DMS SFC,Hotchkis STB,BMR Adjustable PHR,Global West LCA,Energy Suspension Tranny Mount,Addco End links.
1/4 Time 14.028@98.04mph
Dyno Numbers
275 HP
300 TQ
For PCM Reprograming use PCMFORLESS.com
1980 Oldie-Goldie Camaro
305, TH350 stock for now
Old Jul 23, 2002 | 08:50 PM
Erik's Avatar
Classic Tech Moderator
Post
You could try bleeding the lines, but it's probably your master cylinder that's shot.
Old Jul 23, 2002 | 10:26 PM
MadMike's Avatar
Post
You mean the parking brake?
It's spring loaded and has notches on it that "click" as it catches. If it's not clicking, the spring is broken.
Old Jul 23, 2002 | 10:28 PM
angel71rs's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by My Mighty White 95 Z28:
</font>
Are you referring to the emergency brake? If so, the ratcheting mechanism might be broken/frozen. You would want to replace the whole assembly as the easiest solution.
Old Jul 24, 2002 | 08:54 PM
BluEyes's Avatar
Post
you might also have a snapped/broken cable. There are three cables - one from the foot pedal and going back, then there are two rear cables (one to each rear tire).
IndyZman
Oct 22, 2015 02:17 PM
Henson071
Sep 18, 2015 04:01 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
