PDA
View Full Version : Classic Engine Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13
  1. Manual or Power steering
  2. Chambered Exhaust?
  3. How to tell if you have EEC?
  4. 406 Pricing
  5. Locked Trunk
  6. 400sb 2 bolt or 4 bolt??
  7. Pontiac TC cover gasket
  8. High Tech Gauges for my 69'
  9. lt-1 turbo 350 need info
  10. Anyone know how to take apart a deluxe seat belt buckle?
  11. Auto to Manual tranny swap...
  12. Difference between M21 and M22
  13. Trusted Vendors
  14. Is this a true SS
  15. Z28 Rs Production Numbers?
  16. Start w/ Engine or Rear-End?
  17. It has happened to somebody?
  18. Heater core
  19. chevy 305
  20. 67 SS and 67 RS Pictures
  21. how hard is it to run 6 speed with pre-86' block?????
  22. 74' 468, What's it worth.
  23. 73 type LT emblem
  24. serial # on a 400 ci block
  25. 6sp tranny swap
  26. More Wheel Questions...
  27. Dont laugh.. too hard
  28. 10 bolt?
  29. 12 bolt rear end dimensions?
  30. 81 gauge cluster swap - out with idiot lights, in with gauges
  31. Compression Check
  32. classic car staus and milage on collectible
  33. Your thoughts on this car:
  34. Anybody got a 1st gen drum brake setup for sale?
  35. Simulation Software
  36. 1969 Camaro Frame Rails
  37. 15x10 too wide stock?
  38. New 1st gen bodies ?
  39. Group Purchase on T56 kits over at pro-touring.com!!!
  40. subframe connecters-advice?
  41. Headers
  42. D-port heads and non D-port headers
  43. What do you think of this Engine Combo?
  44. Carb linkage prob, no W O T - Help!
  45. Clutch for my 302
  46. Got some loose wires - what are they?
  47. Thinking about going to Vortec heads, questions...
  48. 1980 Z-28 Restoration
  49. New engine install......
  50. someone on here asked some carb questions
  51. Replacing Nose/Passenger Fender on '79 Z28
  52. Rack & Pinion
  53. PST products
  54. Disk brakes?
  55. Headlight Gremlins - any thoughts?
  56. Good info for selecting wheel sizes
  57. 68 12 bolt
  58. Frame coating
  59. rim size?
  60. which tranny?
  61. New project car
  62. stock fuel tank and mini tub?
  63. Front end alignment
  64. Moroso Trick Front Coil Springs
  65. What is a 454 shortblock worth?
  66. split bumper conversions
  67. 69 camaro parts worth anything?
  68. Paint question
  69. 77 z28 front end swap to 79 berlinetta
  70. my chevelle engine plans
  71. 94' LT-1 Steering pump mates to old steering box
  72. Car has been sitting for about a year and a half...what to do to get it started?
  73. 79 camaro question
  74. 5spd in a 2nd gen ?
  75. 69 camaro help
  76. v6 ------to-------V8 conversion
  77. Tool Box
  78. coil springs
  79. 4th gen rear end in a 1st gen?
  80. Ford rear ends
  81. Headers and clearance issues
  82. Torque converter
  83. 70 t/a hood questions
  84. Need dyno for XS274/282
  85. Big cube SBC, need head advice...
  86. Help me choose the right carb size!!
  87. Kit for Chevy lovers >>
  88. '67 Carb Float..
  89. 202 heads do any have [] []
  90. 2nd Gen Fuel Cell
  91. two speed tranny?
  92. Is this a good deal?
  93. How do I STOP the HOP?? (2nd Gen)
  94. pagin dirt
  95. East Coast Classic Cars
  96. Shocks
  97. Rear Springs
  98. Valve cover breather
  99. 1st Gen for Daily Driver?
  100. Tire size and 2" drop 67 Camaro
  101. Price of Labor, Engine Swap?
  102. What is the correct color or paint scheme for....
  103. Installing RS lights on a plain jane 69 camaro
  104. Pics of Procharged 454 in my 80 Z28
  105. piston identification...
  106. I am having a hard time deciding on a color
  107. rear window
  108. 72 formula info wanted
  109. Head casting #`s
  110. Where to start
  111. My experience with classiccarsprings.com
  112. Getting a 2nd gen-
  113. Rear Discs and C-Clip Eliminators
  114. Another supercharger question
  115. Who remembers the Cheetah ?
  116. Power door locks and window kits...
  117. Sub-Frame Conectors
  118. Just bought a 1981 Z28
  119. Supercharger
  120. help
  121. Hydraulic Lifter Sequence for a Chevy 350
  122. Dynomax vs Hooker Aerochambers
  123. 400, 350, and 1978 Trans-Am Parts For Sale
  124. Holley blue fuel pump question
  125. Carb Backfiring.
  126. Not a chevy, but can you help anyways?
  127. Camaro Shifter Mount Location
  128. Sluggish when Hot??
  129. max hp and torque for a 2-Bolt?
  130. Black Panther !
  131. 327 question.
  132. Question about Holley Carb...
  133. Mesurments needed for door mirror (round, first gen)
  134. has anyone had to replace a dashboard
  135. Brake Fluid
  136. Areas of concern in late 2nd gens
  137. Edelbrock Air Gap vs. Victor
  138. a/c heater fan rem & ins
  139. 454 with 700-r4 gear
  140. Body Work..........?
  141. Tire size (math formula) query
  142. 1973 Trans AM Taillights
  143. interior swap from a 4th get to a 2nd gen
  144. Bellhousing Bolt pattern
  145. I would like to say that these 1st gen...
  146. maybe you guys could help with a gas tank leak ?
  147. looking for a '69
  148. Backspacing on 1967 Camaro ?
  149. cross threaded block
  150. Engine Combo?
  151. I'm looking for a 67-73 Camaro with an LT1 or LS1
  152. Power valves.
  153. inner-wheel well.
  154. i need tips on building a 350. wanting 500 hp.
  155. What was the stock 15 inch tire size?
  156. 3rd gen rear end in 1st gen
  157. Stock spec front coils....do they settle?
  158. Motor Oil
  159. This one is easy....Torque specs on lug nuts..
  160. POLL - What brand and weight oil are you you guys running?
  161. AGR steering box question
  162. Camaro control arm relocation template / Suspension Help!
  163. Lowerinf "blocks" for read axle question.
  164. ford fairlane
  165. 3rd Gen to 2nd Gen engine swap
  166. no Z-28 for me BOOOOO!
  167. How do i swap a 229 for a 305?
  168. Wheel and Tire combos
  169. Great Q & A site !
  170. best shifter?
  171. check engine light when msd is installed
  172. NASCAR SB2 heads
  173. Complete Fuel System
  174. 1st gen questions
  175. new guy here
  176. What wheels would look nice on a 79 camaro?
  177. 355 engine
  178. Question on Dana Camaros
  179. Weld Pro Star wheel help.......>>>
  180. Hello All
  181. cahmpoin plug to AC crossover.
  182. What are good tire sizes for 16x7 rims?
  183. Suspension SEtup
  184. Horn tech on 1st gen cars....
  185. What is your favorite Classic Camaro movie/TV car?
  186. 2nd Gen LED Tail Lights?
  187. What are you guys doing for aftermarket stereos?
  188. Adding a rear sway bar question
  189. Restoration question
  190. What do you think of this suspension kit?
  191. msd 6al box
  192. Big Shout Out To Damon
  193. gear question
  194. Automatic? Manual?
  195. Got a problem need advice
  196. Looking for info about the '70 Z28/LT1 cam
  197. First Gen Camaro Question
  198. 502 Crate Question
  199. my 81 z
  200. anybody want to trade their 1st gen for my 4th gen?
  201. Parting out 79 Trans Am
  202. LT1 starter
  203. Looking for old muscle cars out west?
  204. look but don't touch signs?????
  205. wiring
  206. completely new!!
  207. 75 camaro look to a 78-81?????
  208. X pipe vs H pipe on First Gens....
  209. Engine Bay Harness....
  210. 81 z28 1/4 mile times
  211. no spark
  212. Disk Brake material questio
  213. CarFax or somthin similar?
  214. What would this run?
  215. 69 Camaro Emissions
  216. Crate motor suggestions?
  217. how do you get to the trunk hinge to replace it? and where can I get one at?
  218. Rear truckarm suspension
  219. carburetor
  220. HELP me finish my carb install - throttle issues....
  221. Am I lucky or what?
  222. Anyone using aftermarket subframe?
  223. Radiator tech question.....
  224. 1970 camaro ?
  225. Quick Ratio Boxes
  226. 1st gen radiator core support repo/fiberglass??
  227. speed demon 650cfm carb Help
  228. 1971 nose on an 81 trans am
  229. Engine update question
  230. Just picked up another Camaro
  231. Anyone running TT IIs on a first gen?
  232. Gold emblems for '76 Trans Am?
  233. my 1980 thinking of selling (pics)
  234. original paint & graphics
  235. starter
  236. Another "what's it worth" ?
  237. 70 z28 ss rs difference?
  238. Looking for.
  239. My 68 Camaro is going bye bye...
  240. Is it my fuel pump?
  241. Opinion
  242. What carb to run?
  243. Is this a good price?
  244. 1980 Z28 w/ an LT1 A4??? How?
  245. g-machines ?
  246. Electrical
  247. N90 aluminum wheels go for?
  248. Question about "Complete Dual Exhaust kit", Jegs
  249. Brake Compatibility
  250. Brake question
