View Full Version : Classic Engine Tech
Pages :
5]
10
11
12
13
- Alternator help....
- Widest rims for a 78 camaro?
- exhaust
- 302 crank
- 350 in 81 Zed
- Just got a 69 camaro, any suggestions on finding a TKO
- very rough estimate on HP...
- whats kinda 4spd manual trans
- Aftermarket driveshaft?
- should I use a PCV valve brether? or the regulars?
- ls1 in a 69?
- Teach me about cam specs....
- How to tell a 350 block from a 400?
- Got my 74 Firebird
- removing transmission
- SBC Head Swap Coming - questions
- Just bought a 1971...need some suggestions
- Please Help! I hope I didn't ruin a set of AFR heads :(
- hooker gheyed me...
- DZ 302 Questions ?
- '79 Z28 350 won't tune right exhaust pops !!!!!
- New car 79 Z28, know nothing about carburated engines. Bad tune?
- Why so slow?
- Request for info...
- '73 camaro neutral safety switch
- Correct pushrod length?
- Clunk from rear upon launch
- Front Spring Problems
- need help tranny problem
- question about sheet metal
- how much HP can a carbed 305 make?
- Cam Break IN?
- Got ripped off I think
- Re-doing the suspension
- Z28 302 engine question
- Reading NGKs
- Search for a 2nd gen... is this worth it?
- 20W50 oil
- About to buy a 78 TA with a 403
- Car Broken Down, Any Suggestions!?
- Oil Pressure
- Block Casting Numbers
- What Other Classic/Muscle Car Boards Do You Visit?
- Old Dodge Magnum Engine
- 2000 rpm idle (even after warmup)
- Valvetrain Questions
- Trans Am 79 1oth Anniversary
- fan pulley wobbles....
- Good methods of improving mp/g
- Too much play in the steering wheel
- Anyone know how to adjust a TH350 linkage?
- flywheel tech
- CHEAP engine
- "Brand new" 1975 Camaro LT
- rear end
- engine help quick please
- Looking for an engine-rebuild FAQ
- help
- Not Starting
- new spring old head set up
- Someone tell me the difference between these 2 Hedman headers.
- Anybody out there?!?
- whats a good company for crate engines?
- what times will I run
- 396sb vs. 406sb
- Points ignition specs
- 454 BBC: stock heads on this combo?
- 496 Stroker
- trans swap
- The new mouse
- Read my plugs, please
- Ford 427?
- powerglide to 700r4
- Best Gen 1 SBC 23* Race Head?
- Appraise my car too!
- Appraise my car, please
- Michigan girl needs help with 81 Camaro Z28
- what is my engine doing?
- 305 and 350 intake??
- rear info needed! please help!
- fuel fountain?
- 5.7 vortec in 1981 Camaro?
- HEI Rebuild Problem
- unleaded fuel
- It needs to be faster.
- Performance Stats for '69ZL1, anybody know??
- i need perf. exhuast 4 81 350 maro
- Would this work, a 79 with a 454
- just bought maro with 1971 chevy 350
- read the thread"(where to start with mods)" and answer it
- where to start with mods?
- 70 camaro sidewinder pipes
- would transmission have to be rebuilt
- 67 a/c
- About to buy my 1980 Z28... what do you think?
- does 81 maro have posi rear?
- B&M shift kit
- takin off valve covers
- The 70 is in the 10's
- Twin-Turbo 307__Supercharged 307
- Is there a tuning guide for the holley 750?
- LT4 Hot Cam and Vortec Heads
- Problem found?
- shifting problem
- Big Block Head Info
- Need help explaining this!
- Will 1990 Suburban 454 work on a 1970 camaro
- 1979 TA 403 times
- How much will I gain from a 750 over 650?
- '69 Camaro - Help! Very confusing brake problem
- '68 Camaro, Big block, high rise intake, and SS hood. Clearance Problems?
- Gear Selection
- New fuel system... almost...
- my 1969 "388" block is missing some coolant holes
- Hhhheeeeeeelllllllppppppppp
- exhaust manifold headers
- can some one PLEASE decode this for me???
- Compression Check ?
- Powerglide to 700r4
- First Gen Camaro/Firebird Interchangeability
- New Engine COMPLETE!!! One minor problem
- Help with wiring up MSD 6al box
- 350 crate motor websites?
- 67 camaro resto, 350 crate motor websites?
- which engine do i choose
- looking for hood
- Tremec 5 Speed
- Indentifying a GM Crate Engine
- i have a friend that just bought a 80 t/a questions for the owners of the 301 turbo
- electric fans where to place front or back?
- Coolant leaking from tailpipe. Pls help!
- Carburator Help!
- shift into overdrive
- Shopping for new front grill kit 67' Camaro *PIC*
- '69 Camaro makeover- Where do I go from here
- What kinda trans is this??
- Yenko Blocks
- fuel pump.
- gen 1 motor???
- Installing 3 point seat belt on 68 coupe?
- Tranny trouble
- anyone ever try to modify a Megashifter to fit a stock 68 console?
- Radiators?
- second gen aftermarket hoods
- My Front Clip FS on eBay
- t-top weatherstripping?
- hood clearance
- miss at 2800
- need help on some specs for a 69 camaro
- Is a Hyd. Roller really worth it?
- dart iron eagle heads 64cc and 200cc intake runner? any good!
- Look What This Engine Shop DID
- dead carb???
- Switching from regulator on firewall
- where can I find info on the 8.2 inch 10 bolt in my 68?
- Please Read: no mo camaro!
- 1969 AC Blower motor location??
- Oil Pressure Plz here
- Hei Ign. Module Trouble
- 1978 Z28 engine rebuild??
- how to make a 2nd gen handle?
- anyone here swap in a 4th gen interior?
- anyone make a t56 swap kit for 2nd gens??
- anyone ever use Unlimited Products fiberglass body panels?
- 76 Chevy van 350 motor
- Engine Code Question (1974? Z28)
- Anbody ever replaced a dash pad on a 69 Camaro?
- Guaging Interest FS: 69 front suspension/brakes etc
- 70 Th350/small block transmission crossmember?
- 3rd gen tilt column into 1st gen?
- LT1 2nd Gen. Junky
- Super charged carb in a box question
- How to find a coolant leak??
- About to buy a 79 camaro- a few questions
- What to Do??
- 1967 Floor Mats
- Suggestion to second/first genners
- electric fan vs. flex fan
- '78 been sitting for a LONG time
- Finally started my Z28
- how much for 67' SS?
- Shock Question
- 69 Bumper Brackets
- AFR 190cc heads vs. GM LT4
- Decoding Question
- 4-spd trans # decode
- nasty backfire at engine shut down
- Tall Deck BBC Headers
- XcYZ
- Gear question and suggestions help...
- Best overdrive transmission for a 69 big block chevy???
- pulley ideas needed - 1968 302 MO
- LS1 sawp in a 1969 Camaro???
- which cam for my 350 chevy engine (no emissions)
- Mono or multi leaf rear suspension?
- brakes no stoppy!
- best aftermarket heads for chevy 302
- Does oil pump need a gasket?
- Is there hope for my cam with the right heads?
- sound clip of chambered exhaust
- need help fast!!!
- I need help fast
- Which exhaust?
- Can I safely remove the EGR setup from a 77 350?
- Gas Tank Guru's/Knowledged Inside Please:
- Questions about a 77 Monte Carlo/350 hopefully you guys can help...
- Timing mark on balancer
- how precise?
- good web sites for big block??
- AN Fuel fitting sizes
- Trunk
- fan t-stat makes radiator leak, help!
- 71 Camaro For Sale
- need help with my basket case
- th 200-4r in 69 camaro
- 81 6 cyl. sport coupe + 78 vette 350?
- are the 2nd gen good reliable daily drivers?
- 455 Build-up
- For Sale ported LT1 carb intake & other stuff
- For Sale Built 700R4
- Any of you guys with 1st gen. camaro have problems with fuel deliver?
- Cal Tracs for sale
- 68 Camaro with LT1/4L60E in for sale section
- aftermarket instrument cluster
- Installing timing cover without dropping oil pan
- Help me get my car cranked
- net VS gross?
- Electric Fans?
- sound clips of new exhaust.........
- New Guy, with a new to me '79 Camaro
- 1979 Camaro - Popping out u-joints
- Best exhaust for 1st gen camaro
- Carb Settings?
- Looking for suggestions
- I need this stinkin carb....lol
- ** T56 Tranny in 2nd gen **
- Engine Timing?
- 1955 Chevy Pickup Restoration?
- Subframe connectors for 69 camaro???
- Vortec 350 intake?
- Issue with a 1968 Z28 w/ 2x4 bbl carb setup
- rebuild
- Help me out w/ torquing aluminum heads.
- BBC Fuel Pump Installation ?
- Fan Shroud
- 3rd gen steering box in a first gen?
- 80 camaro exhaust popping.
- Help weird stalling and bogging type things..??
- Anyone need a second gen fiberglass L88 hood CHEAP?
