77 Trans Am performance mods?
Old Aug 3, 2002 | 12:38 AM
Zomie's Avatar
Post 77 Trans Am performance mods?
So what could be done to a 77 Trans Am witha 400 engine?
Like intake, carb, etc.,
Old Aug 3, 2002 | 07:57 PM
IRONFIST's Avatar
Smile
Um... a ton of stuff. What kinda' heads does it have? It depends on how fast you wanta go.
Cherry Black '76 Firebird,400,COMPXE268 ADV 2*,6X-4'S (8.4:1),PERF-RPM INTAKE,2.46's,1,5/8"headers, 2.5" duals, TH350...
2002 Cavalier, daily driver, no mods. 17.337@79.80mph@3500'
Old Aug 4, 2002 | 07:53 PM
slow77ta's Avatar
Post
Headers and full dual exhaust, good tune up, cap/rotor, plugs wires, fast timming curve, set total timming to 40 and you will be running good. Good basics.
Old Aug 4, 2002 | 08:56 PM
AJ1978TA's Avatar
Post
In order to get the car off of it's ***, you need a cam, if not do something to the heads as well. My car went 15.2 with headers and exhaust + K&N/open scoop, as opposed to low 16's w/ stock exhaust.......The cars are SEVERLY detuned.....The '77's have like 7.7:1 compression, so getting a cam that will work on that low compression will be hard to find; unless it was a damn 350 chevy.....When I was looking for a cam for my stock heads and compression (8:1), all I saw was a high energy 252H or 260H cam.....If you have the $, try to mill the heads or get different pistons to raise compression, then get a cam, and definitely an edelbrock performer intake/carb combo. The stock exhaust, cam, heads, intake, and carb all suck. Replace as many as you can. If you can't do anything to the heads, get a small cam, it will be better than stock, and get the intake/carb and exhaust to go with it. True duals with headers, and no cats. Open up the scoop as well; it made a very noticable difference on my car. Basically the only free mod for this car.
1978 Trans Am, will be alive soon, engine being rebuilt.....I'll get out of the 15's someday... http://www.cardomain.com/member_page...=225185&page=1
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
