tire size for 67 bird
Old Aug 21, 2002 | 06:00 PM
anuarism's Avatar
Post tire size for 67 bird
Like the post says, what size tires will fit on a 67 bird with 14" rally II rims. It has 195's but i want to go wider but not sure how much will fit.
Old Aug 22, 2002 | 02:45 AM
nape's Avatar
Post
You should be able to go to 205, but check with your local tire shop. Usually the guys are pretty knowledgeable if they don't have their heads shoved up their a$$e$ like my local place :\
Old Aug 23, 2002 | 03:46 PM
Dr.Mudge's Avatar
Post
I had 225s on my 69, I forget if they were 60 or 70 profile though. I believe the wheels were 14x7 but they could have been 6", it was so long I can't quite recall.
Old Aug 24, 2002 | 08:32 AM
popskull's Avatar
Post
I've got 205's on Rally II rims on my '67. I'm sure you can go a little bigger on the back tires, but I think you will run into rubbing issues if you go too much bigger on the front tires.
Old Aug 24, 2002 | 01:14 PM
anuarism's Avatar
Post
Thanks for the info. I just got it about 3 weeks ago and tires are the first bug thing that has to be done to it.
HectorM52
Jul 30, 2017 11:46 AM
LD Kirk
Apr 30, 2015 08:54 AM
shroyvin56
Apr 3, 2015 08:15 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
