fuel delivery question
Old Aug 22, 2002 | 10:47 PM
Timberwolf's Avatar
Post fuel delivery question
I have a Walbro inline fuel pump I had planned on using on a 4th gen I had a while back, but never got to it. Right now I have a 69 with a 454 and it seems to run out of fuel at the mid/top of 3rd gear. I was thinking of using the walbro, but am wondering what regulator will handle the pressure. It is a 255lph unit at 80 psi. Anyone know which FPR will drop it down to 7-9psi or so for a carbed motor?
Old Aug 25, 2002 | 10:30 AM
bestracing's Avatar
Post
The fuel pumps that have high flow numbers that are made for carb applications (like BG fuel pumps) have a bypass regulator built in them and return the unused fuel back to the tank. Barry Grant makes a bypass regulator that is mounted near the carb but I don't know what kind of flow it an handle. Your pump might be a little too much for a carb applicaton.
Wayne Best
Best Racing
67 rs Camaro
  • 355 cu in Chevy
  • 12.5:1 compression
  • 10.90s @ 120 mph
87 Formula 350 w/388cu.in. motor
www.geocities.com/best_racing
[This message has been edited by bestracing (edited August 25, 2002).]
Old Aug 27, 2002 | 10:15 AM
yzguy's Avatar
Post
I would not use a FI pump on a carb... you may be able to get away with it using a good return style regulator, but at verry least you will wear out the pump too soon..
Regulators (for the around 5-15 psi) are not made to take the pressure of 80 psi and drop it to carb range.
I would ebay that pump and get one that was intended for a carb.
69 Camaro among other toys.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Jul 4, 2005 05:00 PM
