Cam choice...
Old Jul 8, 2002 | 08:34 PM
BluEyes's Avatar
Post Cam choice...
Here's the combo:
-350 +.04, ~9.5:1 CR
-Q-jet carb (750cfm)
-Very ported Q-jet intake (will get a single-plane intake later)
-882 heads, ported (~170cc intake runners), 1.94/1.5, screw-in studs
-Summit cheapo headers (1 5/8")
-2.5" exhaust pipes w/ glasspacks, and probably cutouts
-TH350, 2500 stall, unknown rear gears, and short (24.6") rear tires (225/60-14")
I'd like the engine to be able to pull to 6000-6500rpm, have enough vacuum for power brakes, and (of course) as much power as practical!
What I'm looking at is the Comp Magnum 282 solid cam:
236*/236*@.05, 110*LSA (104*IC), .495/.495 lift.
Remember, this is a solid lifter cam, so it should behave like a slightly smaller hydraulic cam, right?
Engine analyser predicts 170# cranking pressure, and 13.8" of idle vacuum with this cam.
I've also considered getting a Howards or Schneider custom solid grind with 236/242@.05, thinking my exhaust might like the extra duration?
Could I/Should I run a larger cam with 9.5:1 & iron heads (never tuned an engine before - I don't want to have to worry much about detonation).
Loosing some low-end doesn't bother me - the suspension will be set up towards handling, and the cops here are very touchy about squealing tires, so I don't want to have to worry about hooking up loads of low-end torque!
Any thoughts?
Old Jul 8, 2002 | 08:57 PM
joesmith69's Avatar
Thumbs up
Sounds like a nice little combo. I wouldn't bother using a bigger cam then the 282S with those tiny *** heads. I think you'll like that combo as it is. If anything I'd go to a performer RPM and a speed/mighty demon carb. With a good free flowing exhaust and decent port work on the heads, you could easily make 360-370hp.
Have fun.
-Joe
79' Z28 4-spd
http://joesmith59.freeservers.com/
*Boycott Lapeer*
Old Jul 9, 2002 | 08:00 PM
BluEyes's Avatar
Post
well, I'm hoping the portwork I've done on the heads turns out well (crosses fingers). They are somewhere around 170+cc's, and a far cry from the soot-covered things I started with. We'll see...
On the cam, I was hoping it'd perform somewhere between an XE268 and a XE274, because I've always heard to subtract 5-10*@.05 when going from solid to hydrauilc due to the valve lash... As long as it pulls to near 6K with the current setup, I'll be happy.
Old Jul 10, 2002 | 12:00 AM
joesmith69's Avatar
Thumbs up
That cam will easily pull to 6,000rpm. I had a 355 with sporstman 2 heads and a 228*@.050" duration .480" lift hydraulic that I shifted at 6,000.
-Joe
79' Z28 4-spd
*Boycott Lapeer*
Old Jul 10, 2002 | 09:35 AM
gs400tx's Avatar
Post
I would go with a newer XE solid. The 282S is kind of old. See what the specs are on one of the custom grinds.
Old Jul 10, 2002 | 07:08 PM
BluEyes's Avatar
Post
if I got a custom cam, I'd have it about 236/242@.05, 110LSA, and .52"/.52" lift w/ 1.6 rockers.
I figure .5" net lift (after lash) is about the limit of both the springs and the valve guide-retainer clearance...
I didn't think the XE solid cams were out yet? Have to check comps website...
Old Jul 10, 2002 | 11:32 PM
joesmith69's Avatar
Arrow
I'm pretty sure the XE solids can be gotten. Don't think they are in the catalog, but you can get em.
-Joe
79' Z28 4-spd
*Boycott Lapeer*
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
