Oil leaking out of intake bolts....
Old Aug 28, 2002 | 01:45 PM
BamaZ28's Avatar
Post Oil leaking out of intake bolts....
The drivers side was just like pumping oil out of the intake bolts. Has anyone had this problem?
Old Aug 28, 2002 | 02:00 PM
yzguy's Avatar
Post
yes I have.... it made a small oil pool right under the offending bolt.
fix for me was to pull the intake and use a light coat of the same silicone I used on the end seals around the leaking bolts like I do around the water jacket. Not supposed to need it with the silicone gaskets, but I do it anyway now.
69 Camaro among other toys.
Old Aug 28, 2002 | 04:27 PM
Polecat's Avatar
Post
yep...do the same thing. Add a tad of silicone...presto!
Speed-O-Motive 383 stroker kit,4 bolt 350 bored .030 over,TRW Forged pistons,Moly Rings,Comp Xtreme 284 cam,.540 lift with Crane 1.6 roller rockers,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves, Comp guideplates,Edelbrock RPM intake,Holley 750DP carb,Hedman 1 5/8 headers to 2.5" duals and flowmasters,HEI with MSD6A box,TH350 with Hughes 3000 stall,4.11 gears.
Old Aug 28, 2002 | 11:07 PM
clydes ryds's Avatar
Post
Maybe some silicon on the leaky bolt,also.
Old Aug 29, 2002 | 12:12 AM
BamaZ28's Avatar
Exclamation
Thanks guys, I decided to tear off the heads and have them re-done so I can drive her around daily (getting married), how much to redo stcok 305 heads these days with new springs? Thanks
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
