rear shock relocation and 17X9.5 wheels on a 67 ?'s
Old Aug 17, 2002 | 08:11 PM
Paul69camaro's Avatar
Post rear shock relocation and 17X9.5 wheels on a 67 ?'s
got a buddy with a 67 that is trying to move the rear shocks inward to fit a set of 17x9.5 wheels back there, i've seen a kit but can't find it any where, those any one know who makes one and what all is involved in getting the ZR-1 wheels to work on the back. thanks
Old Aug 18, 2002 | 08:47 PM
68 Camaro Conv's Avatar
Post
I know summit has a bracket for moving the tops of the shocks to the inside, not sure if you have to move the bottoms though.
Old Aug 18, 2002 | 10:11 PM
camcojb's Avatar
Post
I've never owned a 67 and I know the shocks are mounted differently, but on my 69 the 17" wheels go over the shocks; there is no reason to move them for clearance. I thought the 67-68 were the same as I've seen many with 17" wheels that did not re-locate their shocks. On mine, the inner fenderwell is the first thing to get in the way, the shocks are no problem at all.
Jody
MY CAMARO
Old Aug 19, 2002 | 10:52 AM
Lowend's Avatar
Post
I have seen a lot of 67/8 Camaros with 17x9.5" wheels on the back with no mods to the shock location.
Take a look at www.racehome.com Tony, the owner of the site has an uncut '68 with 17x9.5's out back
1971 Camaro
12" brakes
16x10" wheels
VSE swaybars
350 / M21
Autocross Competitive
'83 FSP GTI (driver)
Administrator; 2nd Generaton Camaro Owners Group (2GCOG)
www.nastyz28.com/2gcog/2gcog.html
Sales / Tech
"The Speed Merchant" - San Jose, CA
Old Aug 19, 2002 | 12:14 PM
Post
i don't think that tony's car has stock rearend setup though, another thing what size adapter is needed for the rear to fit the ZR-1 wheel on there? I always thought it was about an 11/4 inch adapter. Am I wrong?
Old Aug 19, 2002 | 12:38 PM
DCLXVI's Avatar
Post
Yeah, that rearend looks far from stock. I put a 1 1/2" adapter on my 67 and the top of the 17x9.5 rim rubs agains the top of the shock absorber. So it looks like either (a) relocate the top of the shock or (b) get a 2" adapter. By the way, I'm the guy Paul is referring to in the first post. If anyone has a better solution, I'd be delighted to hear it!
Old Aug 20, 2002 | 11:24 AM
Lowend's Avatar
Post
True, Tony has a 9" in his car... but it dosen't move the shock towers.
You need to have 4" Backspace on a 17x9.5 wheel to fit the stock well
Old Aug 23, 2002 | 03:50 PM
Dr.Mudge's Avatar
Post
Guys, do 4th gen Z-28 wheels fit without modification?
Old Aug 27, 2002 | 10:57 AM
DCLXVI's Avatar
Thumbs up
We'll find out for sure this Wednesday...I've got a set of 1999 Camaro SS wheels I'm gonna slap on. Not ENTIRELY unmodified...you need 2" adapters in the front and 1 3/4" adapters in the rear. I'll post pics...
Old Aug 27, 2002 | 12:36 PM
Greg Nolte's Avatar
Post
I have 8.5x17x56mm ZO6 wheels 245/45s on the front. I pulled the springs out and put the wheels on with threaded rod to check to see what I needed for a spacer. Ended up going with 1 3/4" but I have a 89 TA gearbox in it and it has tighter stops than the stock one. I wanted to have it set as low as possible without hitting. The fender hangs over the tire about an inch.
Cranberry Red 69
SS Convertible
95 LT-1 / 4L60E
Old Aug 27, 2002 | 02:47 PM
Dr.Mudge's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by DCLXVI:
We'll find out for sure this Wednesday...I've got a set of 1999 Camaro SS wheels I'm gonna slap on. Not ENTIRELY unmodified...you need 2" adapters in the front and 1 3/4" adapters in the rear. I'll post pics...</font>
Wrong wheels Z28 wheels are just 16x8", was going to pick up a set dirt cheep.
Old Aug 27, 2002 | 03:06 PM
DCLXVI's Avatar
Talking
I've given some serious thought to just going with the later model Camaro 5 spokes (16x8) just because of the lower hassle level and cheaper tires. Also, the guy I'm supposed to be buying the ZR1 rims from might be flaking out. That seems to happen a lot!
Old Sep 2, 2002 | 09:12 PM
DCLXVI's Avatar
Talking
Well, I went ahead and did it. 17x9's off of a '99 SS. Wound up using the 1.5" adapters in the front and the 2" adapters in the rear because all four wheels rubbed when I did it the other way around. I have Wilwood calipers up front, though, so they may have some offset built into them. Anyway, it works great now, no rubbing, drives like a dream, and looks trick! Here's some pics:
http://www.acheronsystems.net/67/67ZR1.jpg
http://www.acheronsystems.net/67/67ZR1_2.jpg
http://www.acheronsystems.net/67/67ZR1_3.jpg
[This message has been edited by DCLXVI (edited September 02, 2002).]
Old Sep 3, 2002 | 07:10 PM
Dr.Mudge's Avatar
Post
Damn, if I kill you can I have your car?
Damn sweet looking, I can't wait until I get a first gen again...
Old Sep 3, 2002 | 11:59 PM
DCLXVI's Avatar
Thumbs up
Hmmmm...if you kill me you can have my car on one condition: You take over the payments on the other two!
Anyway, it's a good thing I deleted the license plate in the pics!
