1971 camaro pitman arm
Old Jul 19, 2002 | 11:18 PM
kingotheblock's Avatar
Post 1971 camaro pitman arm
I am looking the the power steering pitman arm, (I am upgrading from standard to power steering).
Also, I need to replace the driver side turn signal lamp, below the 'full' bumper.
Thanks,
Ed
Old Jul 20, 2002 | 12:28 AM
texlurch's Avatar
Post
I am doing the same on my 70, I have a box off an 86 Monte SS and the length is different, so I plan on doing some junkyard hopping. The chassis is the same thru 81, so I am assuming the pitman off any power steering camaro or bird should work.. or a 75 or newer Nova/Ventura..
If any one knows any different please correct me?
I put a newer box on my 68, and the power steering pitman off the 68 box bolted right up, just had to change hoses to the newer o-ring style, so I hope GM kept their usual interchangability!
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old Jul 23, 2002 | 10:39 PM
Post
I was under the impression that the Firebird and the Camaro, although both F body style, use a different pitman arm, (what's different, I don't know for sure). The A body, Chevelle, Monte Carlo, El Camino, use a 5" (hole2hole) pitman arm, with the splined socket at 1" (Camaro is 1 1/8th"), the centerlink connection is 9/16" (Camaro is 5/8"). ..so much for the "GM usual interchangability!"
...still looking for a 70-81 Camaro pitman arm, folks....
Old Aug 8, 2011 | 12:03 AM
lackneramanda's Avatar
BANNED SPAMMER
Re: 1971 camaro pitman arm
Hey guys, I'm a newbie with a pitman question. I did a search and found a few answers but I can't tell what size the BIG nut is on the pitman arm of my Blazer. I would like to just go and buy the one socket I need for now. Thanks in advance.
___________________
93 Formula Mods: 383, LE2 Heads/Intake, 226/230 cam, 52MM TB, Magnaflow cat back, LT headers, pitman arm, CAI, SFC, Strut Brace, Adj LCA, Adj Panhard, Relocated Torque Arm, Progressive Rate Springs, Short Throw Shifter
1775.Z28
Jan 11, 2015 10:51 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
slothgrant
Aug 22, 2002 03:01 PM
