View Full Version : Classic Engine Tech
Pages :
10
11]
12
13
- Shortest sbc waterpump?
- 67 Rs, 70 Ss
- Questions about '01 5.3 in my '79 Z28? EZ
- Tachometer Suggestions
- blue 79 Z/28, quick ?
- Started the Blown 68 (vid inside)
- May be getting 1995 350 for my car, help mods...
- wheels fitment question
- Muncie 21 andM22 tranny questions...Help!!
- Stolen 68
- New Edlebrock Performer RPM intake For Sale!
- 1967 Camaro for sale
- exhaust ?
- Help on 69 Suspension build-up
- Should I buy this 81 z28??? Need some consulting!
- what size exhaust?
- best resto parts company?
- Hei or MSD?
- Will this work? 69 Camaro front end on 69 firebird?
- For Sale
- WTD: 3-wire o2 sensors
- Real Z28 RS or Clone?
- Installing a heater core in a 67 Camaro?
- Questions for 1st gen owners...
- 67 Camaro build up
- Camaro For Sale
- Easy question about stall converters...
- New rear gear 4.10 What a Difference!!!
- ? About 80 Z
- Year One makes it right
- Gas in vacuum advance cannister?
- Salvaged Title on a '67 SS Clone
- 67-69 Hooker 1 7/8" long tube headers For Sale!
- Transmission switch
- Can a torque converter go bad???
- Custom exhaust system
- FI in 1st Gen
- Have all of Engine 'cept cam....help?
- Reverse Lights for 1969 Camaro
- Replacing the rear main oil seal
- Lowering an 80 z28
- Original Fuel Line
- anyone know of a Buick Turbo 3.8 swap being done in a 72 formula?
- Question about a strange oil leak...
- lt1/4l60e intsall in a 1969 camaro
- First Gen Seat Upgrade
- Whats your favorite car of all time.
- th-700r4 in an 81Z???
- pillar pod
- 1969 z engine identifacation help
- Question about Rat motors
- Suggestions on my next mods
- Chevelle websites? sbc dedicate ubb?
- FS:Vintage air a/c setup of of 69 Camaro/misc stuff
- Ya'll Probably think I'm stupid!
- Gauge Mounting on Driver's A Pilliar 68
- tunning for cold
- Door Lock
- How do you wire in a Kill switch?
- ls1 radiator
- LT1/4L60e swap into my 78
- a few 2nd gen ?s
- Getting ready to take block to shop, quick questions for you
- Points to HEI, Power loss?
- MUST SELL 1978 Z28-Motivated Seller
- Who makes headers for an LT1 swap into 1st gen?
- LT1 swap, transmission questions
- Anyone used/using Rhoads lifters?
- Anybody know how to identify GM crate motors?
- Road Demon Carb?
- distributor
- FS/FT: 4 speed setup for 1st or 2nd gen
- warning! year one ls1 1st gen headers
- Freezing Balls
- Looking for some thoughts on LT1/T56 swap into 69
- Tbi
- at od that fits pontiac 400 engines?
- 1969-1970 Z28/LT1 engine parts
- tranny swap
- speedometer
- Should I or shouldn't I? (trade my 4th gen for a 2nd gen)
- 70 TA w/400 pontiac / 6 spd???
- Will 4th gen backseats fit into a first gen?
- 6spd help please
- 81 Z engine rebuild
- GM 385 HP Fast Burn Longblock, anyone here with it/dyno#'s, info,
- 67 camaro for sale
- Paging scooters97ss
- I need some help.
- converting from leaded to unleaded???
- 17in on 78TA
- exhaust question= borla
- Brakes
- Will these wheels fit??
- torque converter for sale
- The Ls1 Lives!!!!!!!!
- hood clearance
- 142 & 177
- hey... im new...
- Gen 1 Projects
- Big Block chevy & other stuff for sale
- X.xx = Xx C.i.?
- signs of an intake leak
- 1979 T/a
- need help, about ls1 swap. important
- pic of my car
- 393 or 406 which one should I build?
- Universal Radiator Brackets
- Swapping old to new gurus...
- Must Sell '78' Z28 - Redford, MI
- 71 Z
- Value of a 79 Z28
- Newbie
- 67 Camaro Value
- Must sell 1978 Camaro Z28
- CD Player In my 78?
- 79 Z28 less motor/trans $1500 lots of new(er) parts
- i wanna spray, what plugs
- timing question
- Ss Proof?
- 68 Gas Tank
- Tilt Column?
- Smog laws in CA for a 75?
- 68 trans am camaro! what is the body worth
- 1981 tranny's
- New to the "old farts" help me out
- Low Mount Alternator brackets
- MustangII suspension question?
- sound like a sticking thermostat ?
- 68 windshield... how much? need help ASAP
- Isky better than Comp?
- 383, cam selection needed
- need info on 79 camaro
- ign.?
- Is anybody useing the edelbrock sbc street tunnel ram???
- I got new pics!!!!
- Kinesis wheels on a 71 bird
- Man, long time no post.
- I need some help!
- Quick Q-Jet question
- lowering rear of 67 camaro???????
- head question
- 4th gen rear brakes onto 67 and up???
- 68 RS fenders and lights....
- 350 cam, questoins
- Recommendations for books on shortblock assembly?
- Gas tank filler hose?
- front clip for 68
- 72 Camaro
- Dimensions of 68 camaro
- jet question
- 454 Build Up
- th400 problems
- Welcome 2 The 2nd Generation
- 4 Bar suspension
- howmany peaple here have 1st gen ?
- check this out
- wheel sizes??
- 1967 camaro sub frame help
- 350 bottom end -- Main bearings
- 1st gen disc swap
- fitting 17x11 in the back
- ignition switch help
- 383 buildup Cam choice
- Damon and other 406 peeps
- Driver/Pass Windows... No Hardware
- Brakes
- Air conditioning in a 1971 firebird
- Car not running right?!?
- Brakes
- Please tell me if i'm on the right track!
- Please help me with my tech questions!
- Car doesn't crank well
- Is it true you about putting a screen in between your intake and carb?
- SBC exhaust manifolds W/2.5" outlet
- Porting Performer RPM heads
- SBC Message Board
- Serpentine belt question for
- 4 speed transmission experts?Help
- 68 Camaro Selt Belt Setup
- broken valve springs
- Holley 870cfm "Street Avenger" For Sale.....thread in "For Sale" forum.
- Does anyone make an electric water pump for a 68 Firebird?
- Super T10...What type of fluid?
- Biggest rims for a 1968 Camaro?
- Dynoed the car today!
- suspension
- What motor is in my car?!?
- Car is running rich at idle!
- Polygraphite bushings
- breaking in engine
- Another starting problem...
- Rear suspension (leaf springs)
- Wheel and Tire fittment questions
- Difficult restart when warm
- Vibration in driveshaft/rear end...
- Trade/Sale: 68 Camaro front end
- White Lithium Grease
- Performance improvements with a AL driveshaft?
- small black
- Powerglide to 4 speed standard.
- Have a 72 Pontiac 400 and TH 400 what can I do to get most hp possible?
- 77 Trans am heater box
- My 69 Rear Quarters are sticking!!!
- Can you decode this rear axle code?
- carburators again
- 327 1/4 time
- Does anyone have info on Smokey Yunick and esp. his 67 SCCA Camaro?
- how safe are we?
- Question about 1967 Pontiac Firebird
- Wanna go faster w/79 383 ci camaro
- What times to expect?
- need roll cage pictures
- What brand of headers to buy
- Some stuff from early 70's camaro for sale
- Waken up a 350
- oil temp guage and brakes
- Im looking at buying a 67-69 camaro anything to look out for?
- HP/Torque output estimation
- How can you tell......
- LT1/T56 into first gen sites?
- new site
- Must Sell 1978 Z28
- Anyone running a carbed gen 2 LT1?
- t-56 flywheel
- Chilton book
- NOOO, Look at what I missed!!!!
- Need to get a rear-end
- How does an Amp gauge work???
- Can Someone Please Explain This to Me?
- FS: 2nd Gen gauge package
- base $ for a 78 corvette??
- Anyone have any soundclips of a 302?
- Will a 295/60/15 fit under a 1969 rear qtr assy
- What am i Doing Wrong? (Holley Tuning ?)
- my '79Z
- T56 in 2nd gen w/ poncho 455?
- What is best to treat a roof with after removing V-top ?
- Still problems
- searching for 1970 to 1973 firebird or trans am
- My 1980
- deluxe door panels, used or new?
- 383 buildup
- Automatic to standard.
- hood bird
- hotchkis suspension
- Force fuel injection?
- heads?
- Looking for a first gen
- T56 Clutch master stroke?
