How to wire alternator with Painless wiring kit?
Old Jul 20, 2002 | 02:58 PM
jasycZ28's Avatar
Question How to wire alternator with Painless wiring kit?
I am wiring a 69 SS with an internal regulator for an 80's something 350. I got the power going to the post on the alternator. Then looking at the front of the alternator the one wire from the fusebox goes on a prong and what connects to the other prong. The kit told me to wire a jumper from the power on the lug to the other prong. It started smoking so now what?
TIA
93 Z28 M6 Purple pearl
Borla catback
High flow cat
K&N FIPK
Pro 5.0
Air Foil
Hypertech chip
TB bypass
Old Jul 20, 2002 | 04:48 PM
angel71rs's Avatar
Post
You might have accidently shorted to the alternator case. If memory serves, 12v from a keyed source goes to pin 1. Pin 2 gets 12v constant. The easiest way to feed pin 2 is a short jumper to the output stud. Use a insulated ring terminal for the stud end, insulated spade for pin 2 end.
Old Jul 20, 2002 | 05:51 PM
jasycZ28's Avatar
Post
That is what we did. What would cause the jumper wire to smoke?
Old Jul 20, 2002 | 06:22 PM
angel71rs's Avatar
Post
Accidently shorting the wire to something or the alternator is internally shorting. If you have a multimeter, check for a short to ground with the wire installed (check at the stud to alternator case). It should read near zero (short) if it was bad enough to cause smoke. Then disconnect wire from pin 2. If short goes away, spade terminal might have been shorting to the case. Or alternator has the short. To determine that, put multimeter lead directly on terminal 2. Also, make sure pin 2 isn't kicked over to the side.
Needless to say, battery should be disconnected.
[This message has been edited by angel71rs (edited July 20, 2002).]
ldtantlinger92
Jan 19, 2015 01:26 PM
Rich_z28
Aug 29, 2002 10:44 PM
$hawn
Aug 3, 2002 04:59 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
