PDA
View Full Version : Classic Engine Tech
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. How will these rims look on my 1979 Z28???
  2. Getting Head.....................ers
  3. Brakes/engine question/poll
  4. trans question again
  5. Weiand stealth or Edelbrock Performer
  6. How much $$$ for a 1979 T/A
  7. WTB Lower Front Valance
  8. Is it worth it?
  9. Lakewood scatter shields
  10. 327 problem
  11. transmission for a 67 camaro
  12. Fender gills '78
  13. Carb and Intake
  14. 1st Gen. Tramsmission
  15. Overheating
  16. Why is the LS6 engine code given to a big block and a small block?
  17. New Member, '78 350 4speed
  18. blown67 pics
  19. what "all original" means?
  20. 1979 z28 350
  21. ignition wires
  22. how much hp does...
  23. Camaro!!
  24. where can i get?
  25. questions on swapping Olds 455 into a 403 car
  26. rear end
  27. engine problems not running right
  28. Stupid seat belt question......
  29. selling my motor
  30. 327 or 396
  31. shaken while clutchen
  32. Help With mystery motor...
  33. 77 camaro question
  34. how much could i sell this motor for?
  35. ignition switch
  36. Attn. Big Block Guru's
  37. Serpentine for 1st Gen?
  38. Edelbrock Chapman RR heads?
  39. timing question
  40. compression and pistons choice?
  41. Where to buy a disk brake conversion
  42. Seatbelts in 1970
  43. Thinking of selling the car
  44. 4th gen interior in 2nd gen
  45. 76 needs to go on a diet post haste.
  46. THINKIN ABOUT BUYIN A CAMARO for my first car! :)
  47. 700R4 in a '79 Z28?
  48. Post your street/strip small-block combo
  49. Custom hood?
  50. 1970 Camaro SS Tach
  51. heater
  52. My Car Sounds Vicious! Sound and Video Clip Inside
  53. Parting my 67 Camaro out. Anybody want a EFI turbo engine?
  54. Fire up the Grill
  55. 4th Gen Seats in a 77
  56. Help me pick out an intake manifold and carb set up....
  57. Correct Speedo Gear
  58. holley stuff
  59. Anyone want to trade a 67-70 for a 4th gen?
  60. Need Help Finding Parts!!
  61. 4 barrell carb.
  62. Intermediate cable for Emergency brakes....
  63. Demon Carb question
  64. This is my camaro
  65. Eagle or Scat crank and rods?5.7 or 6.0 rods?mains?
  66. heavy chevy
  67. Stout Auto Trans
  68. NEEDED ASAP - Anyone with a nice '69 Camaro Z28!
  69. turning a 76 into a 70
  70. Spring INstall
  71. Need help on header gaskets on zz4
  72. lt1/tpi/sbc ?
  73. Core Plug is Leaking - Need Tips Please
  74. Suspension Questions
  75. RamJet
  76. What are some websites for buying parts?
  77. How much metal in filter?
  78. need info on zz3 engine
  79. L65 info
  80. oil breather
  81. L88 and LS7 Question
  82. How do I get the window crank handle off?
  83. Suggestions on heads?
  84. Where's the #1 cylinder on an older 350?
  85. 400 crank ? specs
  86. $$value of 72 Z28 clone
  87. T56 6-SPeed in a First Gen?
  88. My 68 coupe
  89. driveshaft help please!
  90. Intial Oil Path for Early Model Chev SB
  91. price 79 z28
  92. Carb too small?
  93. Rear window molding removal - '68 bird
  94. What rear should i get?
  95. New Forum
  96. driveshaft ?
  97. My new car - maybe.....
  98. '68 Firebird wheels
  99. Headliner install - 67 Camaro
  100. help with crank,rods,pistons!
  101. 67, 68 Body
  102. 350 steel crank on ebay
  103. First Gen Pros in here please
  104. 77 camaro...question
  105. Anyone ever install an AC system?
  106. Are SS Clones an acceptable restoration approach?
  107. low MPG on '78 350
  108. 1st Generation Forum
  109. New Member needs advise
  110. Changing a Clutch ???help!!
  111. Stall Converter?
  112. Help with stutter!
  113. Motor Is Done!!
  114. lots of small block basics ?'s
  115. 4th gen seats in 2nd gen
  116. BBC build up
  117. Best place to buy short blocks?
  118. bigger wheels causing speedometer probs
  119. seatbelts in a 1st gen.
  120. 4th gen seats
  121. I cant unlock my door!!
  122. where can i get guages for a 68?
  123. How do i shimm a distributor?
  124. new photos
  125. Suspension Upgrade...?
  126. Turbo 6 or BB?
  127. 454 in a 69...
  128. gm water pump pulley part #
  129. couple engine swap questions
  130. paper behind back seat
  131. About Trans-Am rear end
  132. Computers on a 1981?
  133. 383 with low miles forsale
  134. jack points for a 68
  135. 700r4 Ratcheting shifter?
  136. cant shift gears. please help
  137. what trans is in a 79 z28 automatic
  138. 4th gen stuff in a first gen...
  139. need opinions on possible purchase
  140. Looking For A Scatter Shield.
  141. Has anyone here dyed some of their plastic pieces on their old car?
  142. For the Experienced Engine Builders
  143. help i need summits code for 10% off today!
  144. '67 Camaro Radiator Upgrade?
  145. Size of AC Vents?
  146. Old Chevy 302 motor
  147. Lakewood uni traction bars
  148. Rear end question
  149. what the "XX7" code
  150. Please help identify rear end on 69Camaro
  151. Would you pay $1500 for......
  152. aftermarket heaters and a/c
  153. 1971 firebird w/ 400 engine, TH400 trans FS
  154. Heads worth anything?
  155. well...
  156. Brake Light on Dash is on...help
  157. 95 LT1 in 2nd Gen, which headers?
  158. Trouble with '68 Dodge...hopefully you guys can figure it out...
  159. Brakes????
  160. Seat Covers....
  161. water pump
  162. Gen 5 Camaro concept
  163. carb ?
  164. Need spark plug gap
  165. temp question
  166. IT's DONE!!!!!!! 9" Installed
  167. drum to disk
  168. Doors?
  169. Tight engine fit for the LT1 in the 69'
  170. I'm a Noob!!!! Sorta....
  171. acid dipping
  172. Bought the 67 Camaro i showed you before
  173. Exhaust Crackle, Why?
  174. Whats some good 1st mods to do to a 79 TA 6.6L?
  175. what year transam had the strongest engine
  176. How to open the darn hood!?!?
  177. Must Sell 1978 Camaro Z28 Original
  178. Wheels and Tires for 2nd Gen
  179. i'm looking for a 69 camaro rearend??
  180. T56 ~ 700r4
  181. 67-69 Ss
  182. My headlights stopped functioning the other day..
  183. recommendation wanted
  184. transmission lines
  185. Engine problems
  186. New Motor Delema
  187. Gauge Problem
  188. LT1 / 67 Camaro
  189. what kind of theft protection do you use?
  190. what's it worth?
  191. HELP with 67 RS headlights
  192. Gangsta Lean
  193. New Jets to Match Climate?
  194. Want to know everyones opinion on these Camaros
  195. had a little manifold mix up
  196. best ignition timing type for sbc?
  197. Where to start?
  198. Good Price? Good Car?
  199. Clone or Original?
  200. POP Question
  201. cam question guy's????????????
  202. Help with '72 396/402 engine I'm building....
  203. 400 sb, and th350 question
  204. Just wont to say thanks for the replies
  205. Holley Help
  206. HELP Please Front end nightmare!!
  207. "camel hump" heads?
  208. harmonic ballancer ques.
  209. Its A Boy!
  210. hesitation problem almost fixed, ???'s
  211. Power steering conversion
  212. HELL YEAH! Got my girl running again!!!
  213. straight 6 exhaust
  214. 77 Firebird 400ci question?
  215. 350 crank in 327
  216. Wheel Alignment?
  217. Advice on buying a 67 Camaro RS
  218. 383 stroker?
  219. Norwood Strike Question?
  220. rear gear ratios 81z
  221. these heads any good?
  222. )-Ringed Block
  223. where can I get a door alignment tool?
  224. recommendations?
  225. Decisions?
  226. Weld Racing Pro-stars broke
  227. new motor wont turn over
  228. 67 chevelle???
  229. 1980 Z28 Part # question!! Help!
  230. -67 steering wheel help
  231. 4 Speed Tranny Identification
  232. biggest tire size for 2nd gen
  233. Any 1 have pics of 17's on a 2nd gen?
  234. shock choices
  235. Fuel pressure inconsistancy...
  236. Can someone explain Heads to me. I got 2 dumb questions
  237. 425 HP, 355 CID, Short Block
  238. Beating an LS1
  239. pinion shims
  240. Full Framed 2nd Gen?
  241. 1969 Camaro ZZ502 or 2003 Corvette Z06
  242. Need more power! HELP
  243. pan gasket blowout
  244. what do you think about this plan?
  245. centerforce clutch ?
  246. Will Procharger P1-SC fit under 2nd. Gen Hood?
  247. Edelbrock carb questions
  248. No Spark!!
  249. help with building a 327
  250. Vin info on a 69 GTO
