Its finally running
Old Jul 6, 2002 | 01:41 AM
70 Cam Guy's Avatar
Smile Its finally running
Well I started my car for the first time since Spring of 2000. We had a little trouble getting to start because I had the rockers too tight. Then it was also 180* out on the timing. Once I fixed that it started right up! Timed it roughly and started the cam break-in.
So far I've driven it to the gas station and back and around the block a couple times. I think I need to have someone at a shop help me tune because I'm in over my head (I did set initial advance at 12*). I'm happy to say it will start on the first crank and not quit but I am sure its not running up at the level its supposed to be. It does rev really fast, much faster than I remember so thats a good sign. I really like how it sits now. Its low but not overkill and that front sway bar is pure joy . The car sits practically level. I'll take some pics in the morning and post them
Andy
aim: Andyman350
1970 Camaro
pics of me and stuff
Old Jul 6, 2002 | 09:24 AM
Bill B.'s Avatar
Post
Hey Andy, that's great! It's always exciting to get a car "BACK on the road."
Can't wait to see the new pics. Did you do some changes on the suspension, too?
Have Fun!
Bill B.
'69 Camaro SS396 with '81 305:
stock except for Performer intake, 600 Holley vacuum (modded), Perf. Dist. HEI, 1-5/8" headers & 2-1/2" exhaust/turbo mufflers,
beefed TH 400 tranny with 11" street convertor & B&M Quicksilver
3.08 posi 12-bolt
P235/45/17 and P275/40/17 Kuhmos on 8x17 Wheel Vintiques rallys
H.O. Racing front coils, Flex-a-Form fiberglass leafs, Herb Adams VSE body bushings and frt. sway bar, '79 T/A P/S box, power disc front brakes w/metallic pads
Old Jul 7, 2002 | 06:28 PM
70 Cam Guy's Avatar
Post
Well I had some problems getting the oil pressure up so I have to go back and find whats causing the problem. I wanted to take some pics of it in the street but I should wait until I figure out whats wrong before I move it again
I put a new pic on the front page but it doesn't show much. I put on Suspension Techniques springs (1-2" drop), KYB shocks, Addco 1.25" sway bar, all new steering linkages, poly bushings. It really does drive 30 times better than I remember.
Andy
aim: Andyman350
1970 Camaro
Old Jul 12, 2002 | 04:52 PM
70 Cam Guy's Avatar
Post
I have pressure!!! 60psi at idle to be exact
It turned out to be the gally plugs above the cam on the front of the engine. I must have assumed, in the beginning, that it would fine since its all covered by the timing cover
Arg now to find a Harmonic Dampner installer. I have the puller but not the pusher lol
Andy
aim: Andyman350
1970 Camaro
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
squarehead
Nov 21, 2014 08:02 PM
guionM
14
Jun 19, 2002 08:30 AM
