View Full Version : Classic Engine Tech
Pages :
10]
11
12
13
- Paging all 1st gen Z28 owners!! exhaust question
- holley help
- Clutch Recommendation
- Classic 1/4, pics, sounds...POST!
- 2nd Gen Mini Tubbing?
- 327 shifting at 7K?
- Prep work before pulling my 327?
- looking for 69 guage cluster for aft mkt guages
- Temporary pics of 50/50- Completed!!!
- weight
- Biggest 1st Gen Tires?
- Best way to sell a 71' firebird??
- Why does the 1970, 1971, and 1972 camaro's weigh less then the 1973 and up
- rear end ratio
- Exhaust
- Can I Get a Good second gen T/A for under $3000?
- ball joints ... HELP !!!!
- I have a question about my '68 Dodge....maybe you guys can help
- how do these parts sound?
- Looking for a 454 block/complete engine and vinal top question.
- 1973 Camaro ---> ALMOST ROAD WORTHY!!!
- what will it run in the 1/4?
- Pro Topline - Iron Lightning heads
- Shorties vs. long tubes
- G-Machine 1st Gens
- Is there any steel spring wedges out there?
- Flat-tapped or Roller for 67
- Anyone Know Where I can Get Power Steering Bracket For My 81 Z?
- What should I expect for $10,000
- When was the first camaro made?
- Original 67' Camaro distributor specs
- flywheel hp to rearwheel hp
- fuel injected 69 camaro
- Sway bar on a 1st gen ?
- t-56 Trans on SBC 350, please read!!!!
- Hey guys...
- Recommended Clutch For 69 Z
- Have I been drinking too much or what?
- 400 sbc deck height
- Pics of the cracked rocker arm
- shock extenders?
- Roll Cage
- Rpm Air-Gap= no power until 3000rpm??
- 1978 gold bird TA lots and lots of parts 4 sale
- 71 Firebird have questions.
- A/C Qeustion on a '72
- 74 vette with a 72 Z28 block question
- advice please?
- cam info
- '56 Chevy w/ 265 motor
- Project F-117 Stealth Details
- stroker motor???
- Rendering of the baddest 1st gen EVER.
- Mini tub
- Shoulder Straps in a Conv?
- LS1 questions
- 1981 z28 air induction
- Coan Torque Converter
- Did anyone see the article in the new CHP?
- Ticking sound from engine.
- 1st gen Update
- 2nd Gen Roll Call: British Columbia
- anyone around maryland?
- intake and carb?
- oil pump driveshaft
- Is there anyone using a fuel cell that has got there stock fuel gauge to work?
- body parts?
- Q-Jet intake help
- need a 9 inch "pumpkin, 28 spline,posi,about 3.5 gears
- sbc 400 heads
- T56 bellhousing?
- Sump or Cell?
- 2bolt main rpm limit?
- New lighter FLwheel
- For sale
- T56 Swap...Yoke
- Those of you that want to do a T56 swap into your first gen! I got something you need
- parts for the body of a 1981 z-28
- Rollcage
- Subframe Connectors on my 80
- Looking into a 1st gen
- I'm desperate for a camaro
- intakes with egr
- what does my 80 Camaro weigh????
- Gunson Gastester
- So how do you like my new toy?
- An Action Shot of the Z at the Track
- Can I use this t-56 with this much torque?
- Best mufflers on an olds 403 in my 79 TA
- 4th -> 2nd gen swaps
- Tryin to make my 350 sound great.
- Slide-a-link Traction Bars
- How much do you think this is worth:
- Just got my MP brakes front disc kit in!!
- 67/68 Camaro body kit, pics inside
- best looking z28 from 76-81
- parts for sale
- Tranny options for a 79' 350 2 bolt
- Sway bars?
- Reliable Chevy torque converter for T-350?
- Hydraulic Roller in a 67 Camaro
- need help quick please
- 18 year old + 69 camaro 454 = ????
- Second Generation interior
- o yeah im pissed...
- Driveshaft WHAP!
- Aftermarket LS1 Harness For Sale
- ? on tunning Q-jet
- Questions about the engine I just bought...
- Help, my 350's fallen and it can't get up!
- need brakes for 1st gen
- Attention: Need 2nd Gen Blackouts???
- I need some nice 1st gen pics
- 69 z28 driveshaft question
- How much A '67 Camaro Posi rear end worth?
- Solid Body Bushings
- T56 into 1st gen
- Having frame work done?
- A couple of engine building Qs
- Custom Interior Ideas
- Powerglide help?
- About shock absorbers
- master power brakes
- Steel cowl hood for sale (69 camaro)
- TH350 Build up.........
- Second gen rims......need help
- What would you do?
- Camshaft identification-Wolverine?
- Restoring '74 Z need advice
- Firebird formula questions
- 76 firebird formula questions
- Know nothing about rims, need help???
- Need some help with '79 Z28 350
- New 1st gen (mostly) site in the works...
- Question about 4L80E transmission and 1st gen. camaro
- First Gen Online info for dummies?
- 69 camaro questions
- Traction Devices
- How much is my 79 Z worth?
- going price for a 67' camaro?
- Electrical or Mechanical
- 385 and 700 swap! have questions
- My next toy possibly?
- I have a question about what type of rearend would be recommended for 750hp
- Fuel pump leak HELP
- 1978 Camaro RS LT (Exterior diffs)
- need help
- 350 Block Stamp
- 67-69 questions
- 79 T10 clutch
- Differences?
- Lifter identification
- 1968 Z28/RS Camaro Productions numbers
- Afterburner headers
- 17" wheel backspacing on a '69
- 305 engines
- What do you think about.....
- Performer RPM Pro-FloŽ EFI System ?????
- Need advice on Tach Placement
- any good 2nd gen firebird website links??
- Help! Need Recommendation On Subrame Connectors 2nd Gen
- Carb size for a 388 stroker
- Fiberglass doors?
- 400 Small Block
- How Much $ Is This Car Worth
- 50/50 body kit design- feedback needed
- headliner
- Anone know where I can find pictures of 2nd gen's???
- Speaker install for a 73?
- How much fluid for a 2 speed powerglide
- For Sale: Rebuilt, matching #'s, M-21 for sale.
- 79 Camaro Interior help.....DESPERATE!!!
- Take a minute and see If I have everything!
- 1st gen rearend size
- 69 Camaro with BBC for sale
- repairing a fiberglass hood
- Definitive 2 or 4 bolt main exterior ID?
- Q-jet overflowing
- will 100 shot kill my 383?
- Its Alive!
- vin ?
- 10 Bolt Rear Build Up Q's
- classic engine info?
- Dont You Just Love It When a New Round of Mods Actually Pays Off!
- tach help
- New to Classic Tech...need help!
- 12 Bolt mounting on a mono leaf
- Pro Touring Qs
- back after a year..... got sidetracked with Rc cars
- oops :P sorry will 16"ers fit
- 67 wiring schematic problem
- wire schematic
- 4L60E shifter
- 400 Sbc???
- 400 Sbc???
- hipo vs lopo B&M converter
- Car storage question
- 2nd gen vids
- cost of a 69 RS/Z28? just currious
- 700r4 in an 80z28
- New To board
- What is the difference between cheverolet Hei coils and pontiac Hei coils?
- New member, 76 LT Suspension
- Bell Housing, which one for 68 Z28?
- New Member
- 1979 Trans Am
- any help on my 84 vette?
- i am back, and got some questions bout my car.
- Someone hit my camaro!!!!!!!!!
- where to find a 69 camaro
- Mounting 3rd Gen seats in 2nd Gen
- How much does my camaro weigh?
- 1978z28camaro
- I need a used hurst or B&M automatic Shifter !
- some BBC parts for sale
- ZR1 rims on a 68?
- Very odd Timing/rpm hunt?! Please read...
- IMPORTANT- Those who purchased and installed T56 kits
- Questions on a 79'camaro witha Pontiac 400 in it.
- Z/28 Emblem parts # for '68-'69 camaro
- McLeod Twin Disc clutch For Sale! (more details inside)
- Flywheel teeth count
- Weird wiring problem
- Heart of the beast, what cam are you running and what times? SBC only please
- need some help asap!
- 1968 stock specs
- ? on Transpak install
- Please help me with my GTO
- Wits end with brake problem
- MSD RPM Pellets?
- $$$ on power brakes
- How hard is it to fix a Urethane front bumper??
- OT: 2nd gen guys in here!
- Tax Return shopping list, have a couple ?'s
- TCI converter question
- Its almost ALIVE!
- First Gen High Beam Headlight still out....
- Wheel adapters for Sale- 6061 Aluminum
- Sorry, FS:Holley670, B&M Megasifter BRAND NEW
- Blown carb gasket
- Anyone have info on these GM part #s??
- Restoration shop for 1g bird????
- White sludge in valve cover air breather.
- High Beam Headlights for 69 Camaro
- how much for a first gen camaro?
- Anybody got an original Vinyl Roof, help needed
- need help on 350 build up
- block castiing number ?
- ok, let's bench build my engine... :)
- BigBlock Heater box
