Rearend Help.
Old Jul 11, 2002 | 12:24 AM
shocker45's Avatar
Question Rearend Help.
how much would it cost me for a brand new Eaton Posi and new 3.73 gears? what would be the best thing to do. i have 650$ to spend. but i dunno. ive been looking for a new rearend or a used posi for over a month. and its just starting to **** me off. im very impatient. itd be a daily driver so i don't want to high gears. i think 3:73's would be good.. whats a good posi to go with?
how much time would posi and gears knock off on my 1/4 time. i have a limited slip 3:23 right now
1967 Camaro SS stock. runs 15.23 @ 91.3 mph... not to bad considering im a 16 year old pizza boy.
Old Jul 11, 2002 | 05:53 AM
Post
If you've already got a "limited slip" rear, you've got a "posi"..... Positraction is just GM's name for a limited slip rear. You could pick up a set of gears and an install kit for $300-350. Cost another couple hundred for a good install.
As far as the cost of a new Eaton, try the vendors like Summit or JEG's, or anyone who advertises in the popular Chevy mags... DTS, Randy's, etc.
This belongs in "Classic Tech" ......
Moving it there
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 11, 2002 | 10:43 AM
shocker45's Avatar
Post
if i already have a posi then how come when i go to heat up my tires only one spins.
Old Jul 11, 2002 | 11:04 AM
angel71rs's Avatar
Post
The clutches in the posi unit are worn out or you don't have a posi.
Old Jul 11, 2002 | 12:42 PM
shocker45's Avatar
Post
okay. im pretty sure i don't have one. how do i find out the size of my differntial. all i know is its a 10 bolt. theres no tag so i can't tell what size.
Old Jul 11, 2002 | 04:22 PM
TDS-70's Avatar
Post
I don't know about first gens, but on my second gen, it's a code that is stamped into the housing itself, no tag or anything like that.
Hard to spot sometimes if there's surface rust and stuff on the axle housing. Can these be decoded like on the second gens?
Hopefully someone more knowledgeable in 67-69 can help ya out!!
TomS.
    Old Jul 11, 2002 | 10:11 PM
    angel71rs's Avatar
    Post
    On the 8.2, the bottom of the housing will be pretty round. The 8.5 has a couple of cast lugs at each side at the bottom of the housing. If the diff is original, it's an 8.2.
    Old Jul 11, 2002 | 10:44 PM
    shocker45's Avatar
    Post
    are those the only 2 possibilities. 8.2 or 8.5 ? isn't there also 8.75?
    Old Jul 12, 2002 | 11:39 AM
    Another Red Z's Avatar
    Post
    Yes there is a 8.875 but that is the 12 bolt rear. Your car should have the 8.2 if it is orginal the 8.5 started in 1971.Try getting the part number off the ring gear (if they are still visible)GM dealer should be able to tell what rear it is.
    1994 Z/28 M6 t-tops not stock
    1970 RS Camaro 383/th350 4.10's
    1987 C20 parts hauler/beater
    Kinglouui
    May 26, 2016 11:05 AM
    David Dempsey
    Mar 12, 2016 12:42 AM
    truecontr3
    Oct 11, 2015 09:30 AM
    surreybrad
    Sep 29, 2015 09:00 PM
    damnyankee36
    Sep 9, 2015 07:06 PM
