Neutral Safety Switch
Old Aug 19, 2002 | 10:05 AM
Topless TA's Avatar
Question Neutral Safety Switch
Floor shift model, how difficult to change?
Can it be bypassed
thanks
j
cognito ergo zoom....
Old Aug 19, 2002 | 10:53 AM
AJ1978TA's Avatar
Post
I remember when I got my headers, my mechanic had to bypass it, and rip it out, because of no clearance on this damn car. He ended up being able to rig something where I can just turn my steering column myself and the reverse lights will go on or off. It made the car be able to start in just about any gear, if I remember. All I know is that it is not all that hard to pull out I believe, but TTT for ya. Yes, it can be bypassed is all I know. My local mechanic knew how to get rid of it easily and rig me with that column thingy I was talking about in a matter of minutes.
1978 Trans Am, ENGINE FINALLY DONE! Will be running soon! Pontiac 400 + .030", milled/decked 9:1 comp., High Energy 268H cam, comp cams rr's, valve job, balanced, edelbrock intake/carb, hooker headers, dual exhaust, flowmaster 40 series 2 chambers, B&M holeshot 2000 TC, B&M ratchet shifter, march pullies and K&N/Xstream. http://www.cardomain.com/member_page...=225185&page=1
Old Aug 19, 2002 | 02:33 PM
yzguy's Avatar
Post
on my 69 auto that shifts on the floor it is the 2 purple wires that go to the shifter (push on type connector). There are only 3 or 4 (don't remember) wires going to the shifter, 2 for the neutral safety switch and 1 or 2 for the back up lights. Unplug the 2 purple ones and see if it will start (in park of course). If it will, then the car will now start in any gear, if not then make a jumper wire with 2 push in connectors to connect the 2 wires, and then it will start in any gear (I forgot if it was connected=on or disconnected=on).
Although, this is there for a reason...
69 Camaro among other toys.
Old Aug 20, 2002 | 09:24 AM
Topless TA's Avatar
Thumbs up
Thanks for the help you nailed it, i didnt mention but it is a 69 bird.
it had a toggle switch installed by the old man that owned it since new (bought from daughter) his own security system she sold it not running but turns out all it needed was new coil. her loss my gain
69 bird 350/350
64215 orig miles
green/green/green
-j
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
