cats not flowing properly?
Old Mar 31, 2004 | 07:43 PM
sp33d33ss's Avatar
Unhappy cats not flowing properly?
The check engine light came on yesterday so i took it to autozone and they said that the cats weren't working at optimal efficiency. I got the car back 2 days ago after putting on a gmmg exhaust (sounds great, btw), jet-hot y-pipe (with cats, obviously), jet-hot headers, ls6 intake and mass air flow. check engine light came on on the second day. other than the light, it's been running great. what could be wrong? do i need to replace the cats or send the y-pipe back? thanks!
Old Apr 1, 2004 | 10:11 AM
sp33d33ss's Avatar
anyone? i was thinking it might be because increased airflow through the cats is throwing the computer off... i just need to know before i drive the car back to college...
Old Apr 1, 2004 | 02:27 PM
bombd84's Avatar
my guess would be that the rear 02 sensors that you are using are probably calibrated for the stock diameter y-pipe. If you changed the size of the pipe, it might throw it off and cause it to throw a code.
Old Apr 2, 2004 | 09:14 PM
hurricaine418's Avatar
cats
even though you have the jet-hot product, sometimes the cats dont heat up enough with exhaust mods. if you like the performance you have now, buy the sims.
Old Apr 3, 2004 | 09:07 AM
rncotton's Avatar
Another vote for the O2 Sims. The rear O2's don't serve any purpose other than to tell the computer if the cats are operating properly.
The A/F ratio is determined by the front O2's
DirtyDaveW
Dec 1, 2016 05:37 PM
MadMav
Jun 15, 2015 09:51 PM
May 15, 2015 10:43 AM
R@mpage
Apr 20, 2015 10:02 AM
Fatdog2
Mar 31, 2015 06:50 AM
