Replaced horn and fixed yellow headlight this weekend
Old Apr 4, 2004 | 08:03 PM
LS1 Sounds's Avatar
Here are the write-ups:
Replaced my horn with an exact OEM replacement for < $10.
Fixed my yellow and cracked headlight for < $20 by wet sanding and polishing.
Old Apr 4, 2004 | 09:27 PM
1stls1's Avatar
You tell me, Isee a plastic nipple on the bottom just off center to the left.But on the other pic it is way over to the left!! I'm not too sure if you can wet-sand the headlights. I ued to be a detailer and I know you cant sand or buff plastic. If you use plain ole wax,it will help greatley!
Old Apr 5, 2004 | 06:22 AM
LS1 Sounds's Avatar
There are actually three plastic nubs (nipples?) on the front of the headlight, I didn't grind them down or sand them off or anything... just worked around them. There are some types of headlights that can't be sanded, I think it's due to a coating that is over the headlights.
If you can't sand or buff plastic, how do you think I achieved the results that are very obvious on the before/after pics? BTW, I tried wax, Mother's mag & aluminum polish (which did help BTW), and a cleaner/polish too. None of them did much to help the light.
Hope this info helps someone else with the looks of their car.
Old Apr 5, 2004 | 09:24 AM
cop_camaro's Avatar
UNBELIEVABLE!!!!!
Man, you did a SUPER job!
I don't have the guts to try it.
Thanks for the info.
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
fpete1992
Dec 11, 2014 03:51 PM
