Fan switch question?
Old Apr 3, 2004 | 11:52 PM
alteregoss2000's Avatar
Question Fan switch question?
I installed a fan switch from SLP on my 2000 SS. I also have the cold air induction, air module sensor, 160 degree themostat, the whole combonation to make the engine run cooler, I thought. I took it for a drive today ran the fan on high after it got up to operating tempture to see if the tempture would go down and it did not. What am I missing or doing wrong.
Old Apr 4, 2004 | 01:09 AM
ULTIMTEORANGESS's Avatar
did you atap your car or just go by your gauge?
Old Apr 4, 2004 | 01:32 PM
lastZ's Avatar
dont go by the stock guage....it is Sh*t
Old Apr 4, 2004 | 02:19 PM
2001NBMZ28's Avatar
Yeah, don't go by the guage. I have a 160 tstat and fans programmed to come on early - still reads about 210 at normal operating temps.
Old Apr 4, 2004 | 02:40 PM
so what would be the best way to find out what the temp actually is. It reads just under 210
Old Apr 4, 2004 | 03:27 PM
2001NBMZ28's Avatar
You need to read it with ATAP, Predator, etc. If you want real temps all the time you'll need to install a guage. I have LEDs wired to my low/high speed fans - green lights when low speed is on, red when both are on at my programmed temps. When the car is real cold/real hot the guage is correct - it just reads about 210 when in it's "normal" range. Hopefully someone will come up with a fix one day for us 99-02 guys.
Old Apr 5, 2004 | 08:38 AM
2001NBMZ28's Avatar
We may have a fix soon. http://ls1tech.com/forums/showthread.php?t=156876
Old Apr 8, 2004 | 04:58 PM
Today I got a scan tool from Murrays and plugged into my car in the garage. You guys seem to be 100% right that the gauge is not completely accurate. Just sitting in the garage I got the car to drop to 169degrees F . The dash gauge don't hardly move at all and the scan tool temp drops almost 40 degrees. That seems to me that gm factory equipment should be better than that for 20+ thousand dollars. Thanx for the input guys you saved me a bunch of aggrevation, thought something was wrong with my car.
Old Apr 8, 2004 | 05:05 PM
from what i know alot of people complained about gauge fluctuation so GM decided to change it so it wouldnt move around.
i would youd want your gauge to be as accurate as poosibe.
Old Apr 8, 2004 | 05:17 PM
Angry
the thing that makes me nervous is that guage is so sloppy. I watched the scanner monitor the temp the entire time I had started the car, and theres very little change from the time that it gets to around 150 to 210. Thats a 50 or 60 degree fluctuation, so when or if you were to start to overheat the temp would go 50 or 60 degrees before you could be able to notice.
Old Apr 9, 2004 | 09:40 PM
AL SS590 M6's Avatar
Moderator
The gauge isn't sloppy. It was designed that way on purpose. So many people freak and run to the dealer when there heat guage moves around a lot under normal driving. So to reduce warrantee calls and cost they designed a guage that would pop up to a certain setting and stay there from about 170 to 220. In essence a fancy idiot light with a dial.
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
sfGi8nt
Aug 1, 2002 05:54 AM
