What's the best LS1 F-body year (1998-2002)?
Old Apr 4, 2004 | 03:31 PM
kevinCHOPTICON's Avatar
I have a 94 z28 w/ 130k miles. Thinking of upgrading to a newer Camaro, or even a Trans AM.... Just wondering which year is the best, or if there is any clear difference. Most people will agree that 95 was the best year for the LT1 F body.
Old Apr 4, 2004 | 03:35 PM
ls1speed2000's Avatar
i would say the 2001 are the best ls1's
Knowklew's Avatar
Im gonna say 2000
Old Apr 4, 2004 | 03:41 PM
coogsLS1's Avatar
Im gonna go with 98s
Old Apr 4, 2004 | 03:45 PM
ok, maybe I should rename the thread, What year Camaro do you have?
Old Apr 4, 2004 | 03:50 PM
ive got a 2000 but the 2001's and up came with more power LS6 intake and i believe better exhaust manifolds.
Old Apr 4, 2004 | 03:52 PM
99blackSS's Avatar
I'd say 2001/2002 becuase of the LS6 intake manifold. Other then that all the other little changes are minute. But here are some side notes.
-98 has a gas tank that is about one gallon smaller then the 99-02 gas tank
-98 - early 00 the SSs came standard with good suspension
-00 was the first year for radio controls on the steering wheel
Old Apr 4, 2004 | 04:30 PM
darrens99formul's Avatar
99 of course
Just kidding. No the 01's and 02's as previously mentioned came with the LS6 intake. They tend to dyno about 10-15 rwhp more then 98-00 models. However if your gonna do Headers and LSX intake manifold at any point and time then it really does not matter what year you get.
So the honest answer is 01 or 02 but realistically if your gonna mod then get the best deal you can and don't worry about it. 98's & 99's can be had for well under 15k now
Good Luck with your car hunting!
Old Apr 4, 2004 | 04:53 PM
Omega9's Avatar
01/02 01 being the best
Old Apr 4, 2004 | 05:24 PM
Capn Pete's Avatar
'98 - '00 used a cam with higher lift than '01 - '02, so in theory, if you put the LS6 intake on a '98 - '00 LS1, then you should dyno higher than a stock '01/'02.
Basically, the best year LS1 is the one which you can afford, and the one that you own. They're all good, they all dyno pretty close to one another, so basically pick your price range and/or mileage range that you're looking for, and happy shopping!
Old Apr 4, 2004 | 06:17 PM
Zerocool's Avatar
i totally agree, but 01-02s are teh best stock for stock.
Old Apr 4, 2004 | 06:28 PM
camaro98z28's Avatar
98's are the fastest
Old Apr 4, 2004 | 06:47 PM
Omega9's Avatar
Old Apr 4, 2004 | 06:48 PM
Omega9's Avatar
Yeah, but if you put a supercharger on a......
Old Apr 4, 2004 | 07:01 PM
KamaroL98's Avatar
From my point of view, i work on mine alot, it has all the bolt ons, ported heads, nitrous, and then im getting a matching cam and turbo400 tranny and a big stall in the future so i was better off with a cheaper older LS1 since stock for stock all LS1s run the same anyway all im really in it for is an LS1 motor itself which power train wise is the only thing good.
However, i wouldnt mind spending the extra money on a newer one since they already have the LS6 intake and would come with lower miles n most cases which is REALLY good to have when you start doing head and work to the bottom end of the motor, buying an 01-02 will save you from buying a new intake in the future, plus they are easier to work on becaus they dont have that EGR and some air hoses, and the spark plugs are easier to change in the passanger side becaus of the way the coil packs are on the 99+ models btu the coil packs and EGR is nothing really. Eitherway, you wont go wrong with any LS1. There are LOTS of little differences in them, some help and some dont and when the dust settles they dont really run any different, that LS6 intake is pointless on an LS1 unless you at least have headers and ported heads. If you have the money go ahead and get a newer one with less miles and the LS6 intake.
