fans wont come on
Old Mar 25, 2004 | 07:46 PM
screaminchicken's Avatar
fans wont come on
Ok the car has been tore down for about a week, I installed a new cam, and mac mids.I double checked to make sure everything was connected.I cranked it and it was real low on water so I cut it off and the fans came on, I filled the radiator up and evry thing was fine, then water rush out of the radiator (cap off) so I refilled and rinsed the enginge bay down, then tried again and then the lower hose came undone, finally fixed everything and drove it about 15 miles no problem, today I drive it about the same distant and leave it idle for a second to open the garage (same as yesterday even at a longer idle) and then when I turn it off I hear water filling the over flow and running down the car, Now my fans are not working and my temp. is staying around 200 which is good but the fans not running isn't, I also took the egr, and air pump out, this is a 2000 Ws6, and no tune yet.....oh and I checked all the fan fuses, but don't know how to check the relays....
Old Mar 26, 2004 | 03:44 AM
ttt
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
