K&N filter oil inside the manifold....
Old Mar 28, 2004 | 09:24 PM
WipeOutXXL's Avatar
How bad can K&N red filter oil damage the engine if a little bit gets inside the intake. I oiled it, then put it in the car, then had to leave right away and my engine made some funny sounds for like an hour but i'm not sure if I did any damage of any kind.
Old Mar 28, 2004 | 09:38 PM
Greed4Speed's Avatar
It'll burn along w/the fuel.
The problem would be w/it coating the MAF wires. Clean them off.
Old Mar 28, 2004 | 09:41 PM
WipeOutXXL's Avatar
....must be why my car idles wierd.....as long as the oil isn't too sh!tty fpr the engine. Thanks...i feel better now.....
Old Mar 29, 2004 | 12:32 AM
andrewz28's Avatar
the first thing to do is not put so much oil on the filter. also, there is a bulletin that could void the warranty based off of excessive oil on after market air filters like k&n. there has been problems with damage to the iat sensor, etc and it may not be covered under warranty if you soak the air filter with too much oil.
Old Mar 29, 2004 | 06:46 AM
PhantomTA's Avatar
Moderator
Too much oil sounds like the problem
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
squarehead
Nov 21, 2014 08:02 PM
