Long Tubes On ... New muffler search
I've been looking through old posts ... I'd like to get a consensus though ... What is the best flowing muffler, bar-none? Anything I swap in on my current setup will be pleanty loud.
Right now I've got what's in my sig and it sounds incredible, however exhaust pops are insanely loud now that I'm running LT's and an offroad ypipe ... I'm looking to swap out my flowmaster muffler ... thinking it is congesting my exhaust ... Will all substitution mufflers fit up without having to make new welds / cat-back pipes?
Thanks,
Sean
EDIT: Oh and can anyone tell me where I can find a pair of those dual-flattened oval-center tips that come on the SLP 345hp SS? Are they 2.5" inlet?
Thanks,
Sean
try putting an 18" bullet right behind the Ypipe. that's what i'm planning on running with my magnaflow catback.
i had the MF on with a bassani ORP before and it would give some nasty rasp in upper rpms...now that i have the Flowtechs and orp i'm gonna throw the bullet (had it sitting around so why not) on itand see how it helps.
all i can say now is that i have JUST the bullet on the end of the Ypipe
and it sounds almost good enough to leave it like that!!
Originally posted by CrippleFightin
I'd like to do something like this. So your muffler is gone from the catback and you have a bullet muffler in the y-pipe correct? Is there room for me to put my cut out and the bullet on the y-pipe "I pipe" area if you will? And whats the part number of a bullet muffler from say...summit that I can use for my car? Gracias!
WLK-24222 for 3" in / 3" out, 12" long
WLK-24219 for 3" in / 3" out, 18" long
Originally posted by GoFast908Z
dynomax bullet mufflers! I have 2 of em!
I just got back from having my true duals welded up. Sounds friggin great! (*said with scottish accent*)
Thank ya much, Lahddy
