Paper clip jump on my port
http://img90.imageshack.us/my.php?image=pict01753ye.jpg
That is my diag port with my current scanner cables in it - its a 1993 car with the factory wire harness. What two terminals do i jump in order to extract codes via the SES flash method? Please note the only places on the port that have contacts are the ones with the wires coming from.
my blue wire leads to a purple wire in the back, then the orange goes to tan, black goes to black with white stripe, white - white with black stripe
thanks!
-Brad-
thanks!
-Brad-
Re: Paper clip jump on my port
All I can find is the short the A & B terminals, but I'm not sure which ones those are. If you know that, then you're set.
Got it:
http://mastach.com/index.php?module=...onnectors&l=en
I just noticed that your wires don't match up with this one either.
Got it:
Shoebox has all the info on his website:
http://shbox.com/1/dlc2.jpg
But his diagram doesn't seem to match your connector, if there are no wires in the "A" and "B" postions.
Yes, very stange
sleeperZ96BT
Sep 9, 2015 08:28 AM
