fuel pump only runs for a split second
Old Jun 5, 2006 | 06:17 PM
blk97ta's Avatar
like it says the pump which is new with a new racetronix kit only runs for a second or two i can tell since i have an electic fuel pressure gauge ! it primes then stops ! i checked fuses and fusible links next is wiring and relays ! any other suggestions appreciated !
Old Jun 5, 2006 | 11:18 PM
Re: fuel pump only runs for a split second
When the key is turned on (before starting the engine), it only is supposed to run for 2 seconds. Is that what is happening?
Old Jun 15, 2006 | 10:23 PM
blk97ta's Avatar
it primes then it will run on just the prime once the pressure is gone the car stalls (i hav e an electric fuel pressure gauge ) is there a relay for the pump ? if so where ? i know there is one for the racetronix kit also does the bcm control the fuel pump ?
Old Jun 16, 2006 | 11:20 AM
Assuming from your screen name that were talking about a 97 LT1, there's a fuel pump relay under the "dead pedal" for the driver's left foot. There's also a fuel pump "prime" connector that allows you to apply 12V and bypass the relay to test the pump. The PCM sends a signal to the relay to start the pump, and then turns it off if the engine doesn't start. The PCM need to see the "low res" pulse pattern from the Opti, or it shuts down the fuel pump and injectors.
Shoebox has photos of the fuel pump relay, the prime connector and a set of wiring diagrams (for a 95, but marked for the later models) on his website:
http://shbox.com/1/4th_gen_tech1.html
Old Jun 17, 2006 | 09:27 PM
blk97ta's Avatar
it only runs for 1-2 seconds (THE CAR)i tried running the pump priming wire on the passenger side of the strut tower constantly while cranking and it still only runs for 1-2 seconds ? WTF ? any other ideas ? checked fuses and fusible links
Old Jun 19, 2006 | 10:50 AM
Still sounds like an Opti problem. With no low res pulse from the Opti, the PCM shuts downs the pump and the injectors. Putting 12V to the prime connector to keep the fuel pump running solves the fuel pump problem, but the injectors would still be turned off.
Old Jun 19, 2006 | 11:10 AM
blk97ta's Avatar
it is (was) a new opti from gm is there a way to check the opti or maybe a bcm or what other options i have ? with out buying a bunch of parts that i don't need ! tia
Old Jun 19, 2006 | 06:09 PM
blk97ta's Avatar
well i just went out to play with the car and it started and ran for a minute then died ? WTF !!!!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
