injector pulse width
Old May 12, 2006 | 07:06 PM
Fbody1's Avatar
is the bpw hard coded in the pcm at wot ?,or does the pcm adjust them according to the long term /short term fuel memory(blm/int)?or is it up to the programmer of the pcm? tring to figure out if I need bigger injectors ,I am seeing 18 and 19 ms of pw @6000 -6200 rpm
Old May 13, 2006 | 08:38 AM
Re: injector pulse width
Pulse width is a calculated value. Doesn't matter whether its in closed loop or PE mode. PCM looks at the mass air flow, divides it by the target A/F ratio, multiplies by the long terms/128 (whether is uses the long terms in PE mode depends on whether they would add or subtract fuel) and ends up with the required fuel mass flow rate. Then it figures the pulse width (based on injector flow constant and offsets) required to deliver this much fuel in two revs of the crank.
A 19mS pulse width at 6,200RPM is a 98.2% duty cycle. That's too high. The only question I have is whether the "BPW" is the actual pulse width, since I've seen engines not running lean when DataMaster indicates duty cycles above 100%. Possibly the BPW does not include certain correction factors. In any case, your injectors could stand to be larger.
Old May 13, 2006 | 11:11 AM
BradcTA's Avatar
Mine reads 18mS at 5050 RPM WOT. This is OK? Spark advance is 36 degrees. o2s in the 930-950 range.
Old May 13, 2006 | 12:31 PM
Fbody1's Avatar
I do not have datamaster,yet but I got the #'s from freescan , is this a reliable source? thanks you seem to know it all
Old May 29, 2006 | 01:57 PM
Fbody1's Avatar
anyone use freescan? is it known to be correct?
Old May 29, 2006 | 07:58 PM
At 5,050RPM there is 23.76mSec available for the injectors to fire. 18.0 / 23.76 = 75.8% duty cycle..... that's OK.
I don't know how Freescan compares to DataMaster with regard to duty cycle.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
