How accurate is the Datamaster 1/4 mile calculator.
Re: How accurate is the Datamaster 1/4 mile calculator.
Knowing exactly where to start the calculation from in datamaster is the only problem. Moving it one step either way in the record can cause some big differences. Ive played with it a little and figured it wasnt very accurate
If nothing else it should be very good as a reference tool to use when doing upgrades and test runs.
But how do you know what mph you were at when you crossed the 1320 foot mark, then you have to correllate that with the recording.
Also I would assume you need to have the car running engine only @ 10 readings a second.
This to help get it close as you possibly can. Having a passanger reading this helps but then the added weight will throw off your time (at least 100-230 pounds more)
Could be fuzzy math.
i have datamaster you use the rec and its from when your mph goes to 1 and then whenever you cross the traps, if you dont know what Recording that was, you cannot Accurately figure out your ET/MPH, but you can Approximate at best.
