Datamaster inaccurate engine temp reading?
Old May 16, 2006 | 10:30 AM
mkent's Avatar
I use both Freescan and Datamaster and noticed the engine temp reading does not match the coolant temperature gauge on the dash which always stays around the 2nd hash mark (I'm really not sure what temp the 2nd hash mark is suppose to be). Regardless, the datamaster/freescan readings are usually around 200-210*, the gauge appears to be much less than 210. I have the stock stat in the car. I thought maybe my coolant temp sensor was going bad or that our scanner programs are reading from a different sensor. Does anyone here care to enlighten me?
Old May 16, 2006 | 10:58 AM
BradcTA's Avatar
Re: Datamaster inaccurate engine temp reading?
The second hash mark is about 190-200 degrees. It's not very accurate anyway, so I wouldn't worry about it. The computer gets temp readings from the sensor on the WP, which is also what the scantools read from.
Old May 16, 2006 | 11:00 AM
evilundisguised's Avatar
Yah, and the gauge reads from the coolant temp sensor on the driver's side of the block. Different sensors, and it's likely that the temps are actually different too.
Old May 16, 2006 | 03:44 PM
mkent's Avatar
thanks guys, that's what I wanted to know.
Old May 16, 2006 | 04:09 PM
BlackScreaminMachine's Avatar
yea, historically the guage cluster is not accurate, datamaster is what the PCM uses, to determine whether your in closed loop or open loop. I just had my car dyno tuned yesterday, between runs i was in open loop far too long. So I am going back up to the 180 thermo.
spearous
Jan 12, 2015 11:03 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
