Uploading a tune
Old May 23, 2006 | 10:15 AM
Honda Hunter's Avatar
Uploading a tune
When you upload a new tune does it have the same effect as disconnecting the battery? What I mean is does it have to re-learn etc?
Old May 23, 2006 | 12:47 PM
tapout911's Avatar
Re: Uploading a tune
I was wondering this to, subscribing.
Old May 23, 2006 | 01:32 PM
madwolf's Avatar
Yes.
Old May 25, 2006 | 11:34 AM
CRAZ81's Avatar
After a new tune is uploaded, how long should you wait before you pull another scan to adjust the tune more?
Old May 25, 2006 | 07:27 PM
Demus's Avatar
You should be tuning your vehicle so the BLMs are as close to 128 as possible first, then tuning PE. Once you manage this, you won't have to wait any time as there won't be anything (or much) to learn.
Also, if the BLMs are <128 then the PCM will just use 128 under WOT anyway. However, if the BLMs are >128 then the PCM will use that value under WOT.
Victor Lamb
Aug 26, 2017 02:52 PM
92_RS_305
Apr 19, 2015 01:45 PM
