.lt1 for 3.42 in A4?
Old May 25, 2006 | 07:23 PM
Silver's Avatar
Ok so I'm going from a 2.73 in my '95 A4 to a 3.42 from an M6. Should I rescale a virgin 2.73 file or start with an M6 3.42 file and switch it to auto?
I used to hear from time to time that you really shouldn't rescale the rearend ratio b/c of rounding errors, etc within LT1 Edit.
Old May 25, 2006 | 08:59 PM
rngilliland's Avatar
Re: .lt1 for 3.42 in A4?
I used tunercat so I don't know what LT1edit has. I used the speedometer tool in tunercat to change to a 3.42 ratio from a 2.73 on a 94. I just used my existing bin file. I don't think you can use a m6 file and convert it to auto. I think there are things in the files that are unique to auto or m6 that can't be changed.
Old May 27, 2006 | 12:37 AM
94 NO TOP Z's Avatar
Use the A4 file and type in the new ratio. Since the tone wheels are different on A4 and M6 the speedo will be way off if you use the M6 program. Also, you need the A4 file to control all the shift solenoids and torque convertor lock-up which the M6 file will not have.
Old May 27, 2006 | 03:03 PM
Silver's Avatar
Heck I thought both files were the same and when you checked the M6 box it just stopped looking for auto-type input signals.
vwb11356
Jul 22, 2015 06:51 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
blac94Z
Mar 6, 2015 07:55 AM
blac94Z
Mar 2, 2015 06:03 PM
TitoPR221
Jan 29, 2015 08:00 PM
