98-02 Firebird Cluster in a 93-97??
Old May 5, 2006 | 12:10 AM
Gun5's Avatar
Will it work because the 98-02's are digital odo????
I was looking at clusters on ebay again and noticed all the 97's are digital mostly.. would those work to??? trying to upgrade from 110 mph to 150 mph
Old May 5, 2006 | 10:34 AM
Honda Hunter's Avatar
Re: 98-02 Firebird Cluster in a 93-97??
Best place to post this is the appereance section. Theres some guys there that have done it there. With that said, a 97 cluster would be your best bet wiring wise but you would have to swap your dash for a 97+ also. And to add to that Ive been told LS1 clusters wont work at all but I'm not sure if it's been proven. In the end youre in for more than just a cluster swap. Making the wiring work and swapping dashes would be in your future.
Old May 5, 2006 | 10:58 AM
CollinsAuto's Avatar
itll require a 94up car. also the ls1 dash will have different pulse division and the outputs on the pcm will have to be rescaled. any good tuning shop should be able to adjust it though
Old May 5, 2006 | 11:00 AM
What tables have to be adjusted? What exactly would the tune shop have to do?
Old May 5, 2006 | 11:14 AM
no tables just constants. As far as i know tunercat should have them in the 94-95 eeb file. there should be a tach ouput pulse divisor and a speedometer output pulse divisor.
Old May 5, 2006 | 11:19 AM
Just got done looking over the constants. Doesnt look easy but I suppose it could be done. Opens up alot of doors because the 97 digi cluster isnt easy to get, at least it wasnt for me when I was intrested in doing the swap.
Old May 7, 2006 | 03:50 AM
Gun5's Avatar
so my tuner guy will be able to make the 97 gauge cluster work when I get it in right?? also am i gonna have to change the bezel or can it be the same??
Old May 7, 2006 | 03:55 AM
Mabey you should ask your tuner guy if he can even do it. Or just find a 97 digi odo.
Old May 7, 2006 | 04:07 AM
Gun5's Avatar
this is it right here
Old May 7, 2006 | 07:59 PM
Gun5's Avatar
tttt
Old May 21, 2006 | 10:33 PM
BA383TA's Avatar
If you haven't already bought the cluster, I have a 150 mph cluster from a 96 TA. Bill
Old May 22, 2006 | 09:24 PM
Gun5's Avatar
just got my 95 TA one in today.. damn oil thing needle fell off in shipping ubt i stuck it right back on now im just waitin for my white gauges
Old May 24, 2006 | 08:40 AM
WS Sick's Avatar
How does the OBD 1 computer work in a 96/97 then?
All I changed was my knock sensor, the odometer and all gauges work fine.
Formula Steve
Sep 19, 2023 08:31 AM
David Dempsey
Mar 12, 2016 12:42 AM
IndyZman
Oct 22, 2015 02:17 PM
karpetcm
Sep 29, 2015 10:08 AM
alliance12364
Sep 17, 2015 08:43 AM
