Can I use an a4 pcm in my m6 if I reprogram it
I was curious if I could use a 95 a4 pcm and reprogram it with tunercat and use it in my 95 m6.
Also, I have a spare pcm that was flashed using the wrong version of tunercat. How do I get that fixed??
Re: Can I use an a4 pcm in my m6 if I reprogram it
As for the second question, I assume you mean the 1.98 version of Tunercat, which would corrupt data in the upload process. The flash chips will have to be desoldered from the board and reprogrammed manually. I believe Madwolf offers this service, try his webpage at www.madz28.com.
Nayr
Mar 3, 2023 08:34 PM
