LT1 and ProCharger P-1SC - DataMaster data
I logged some test data (DataMaster EE data) and wanted an opinion.
http://www.transam.fi/emc/Testi%203%202006-05-25.uni
Mods are:
- ProCharger P-1SC, 2 Core Intercooler (8 psi)
(including ProCharger inline fuel pump and FMU)
- Delteq LT1 Opti-Direct Ignition
- Arizona Speed and Marine headers
- Random Technology High-Flow Cat
- Magnaflown Cat-back
Is there something wrong or not?
I’m little bit worried about the fuel pressure. My Autometer Fuel Pressure Gauge 0-100 PSI 6163 shows only 55 psi fuel pressure at 8 psi of boost (AUTOMETER Boost Gauge 6160 Cobalt Series 30 psi). I know that fuel pressure should be like 80-90 psi at 8 psi of boost. If I understand my DataMaster log, motor is not running lean? Maybe that Fuel Pressure Gauge or electronic sender is broken?
Thanks for your opinion.
-vellu
Mods are:
-vellu
Re: LT1 and ProCharger P-1SC - DataMaster data
Your fuel pressure sounds right it will increase with a 1:1 ratio. Base fuel pressure. But if you run FMU it should be higher. What fuel pumps do you have?
I have already ordered Racetronix LT1 F-body fuel pump & harness kit. I like to get rid of that FMU using bigger injectors like Delphi / Lucas 42 lb / hr. '009' Disc Injectors or Siemens / Mototron Deka 4 Flow-Matched 60 lb / hr Injectors (both from Racetronix).
...and new Mail Order tune form MADZ28 or from PCM for Less.
