O2 millivolts
Old May 10, 2006 | 06:21 PM
HaynesFaithZ28's Avatar
O2 millivolts
My 02 reading stay at a consestent 600-900 mv. I this rich or lean and could this be a reason for some power loss?
Old May 11, 2006 | 09:36 AM
Re: O2 millivolts
A range of 600-900mV doesn't sound too consistant. 600mV is close to stoichiometic 14.7:1, and 900mV **might** represent a richer 12.0:1 or richer.
Under what conditions are you seeing these numbers? In closed loop, they should be switching frequently over the range of 0xx-9xx mV. At WOT, you should be seeing numbers in the 850-925mV range. But the stock O2 sensors aren't all that accurate at the PE mode A/F ratios, so they are not real useful for tuning. But if you're seeing 600mV at WOT, is quite liekly that its running lean, to the extent you could be getting some knock retard, and losing power.
Old May 11, 2006 | 09:51 AM
wrd1972's Avatar
Re: O2 millivolts
My O2 mv readings bounce back and forth from 100-900. They appear to be completely random with no sense of order when at idle. WOT is 860-880mv.
AdsoYo
Apr 3, 2013 12:27 PM
DirtyDaveW
Jun 30, 2008 10:17 PM
teke184
Jan 19, 2005 06:49 AM
TDog
Sep 25, 2004 02:56 PM
Bill WV
Aug 4, 2004 09:11 PM
