MAP is reading way too high
Old Apr 29, 2006 | 09:33 PM
Sweetred95ta's Avatar
I let my car idle and at ~980 rpm, the MAP was reading ~.7 bars. This translates to 20.7 in-Hg (70 kPa). This is way too high. Does this mean I have a vacuum leak? I know my brakes haven't been working at all. They are extremely hard to push down. But, my MAF reading ~ 13 gm/sec @ 980 rpm. I guess this could also be a reason my car won't idle down. It idled fine before my M6 swap. Any help is appreciated.
Benji
Old Apr 29, 2006 | 11:46 PM
Re: MAP is reading way too high
How radical is the "Joe O cam"? That's the most likely source of low intake manifold vacuum. Valve adjustment and timing gear alignment could also be problems. A good tune can sometimes improve the vacuum on a high overlap cam.
What changes did you make to the program for the A4->M6 swap?
Old Apr 29, 2006 | 11:51 PM
I didn't make any changes, except turning off the codes that were being thrown because of the computer not being able to find the A4 (ie. TCC Enable Fault, 3-2 Downshift Feedback Fault, etc.). The cam really isn't that radical. It is similar to a GM847, but with smaller lift numbers. The brakes worked when I first put the motor in the car (on the old Hotcam tune), but after it was dyno tuned, they didn't work anymore. I didn't think a tune could cause that. I guess I could get a vacuum guage to verify, but the MAP sensor should be reading correctly. I appreciate everything.
DirtyDaveW
Dec 1, 2016 05:37 PM
lt1matt
Mar 21, 2015 07:35 PM
Amshnock
14
Jan 18, 2015 11:47 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
