seperate Nitrous fuel system.
I want to run a 1 gallon fuel cell with c16 my questions are what are my fuel pump options? Could I use a FI pump and run line pressure at 45 psi and jet it the same as a taped set up. Or if I run a carb pump at 6-8 psi and compensate the jetting how much fuel would the pump have to flow. Would a standard Holley pump work? I have seen a set up like this using the Holley blue pump but is that over kill? Any opinions would be appreciated.
