question about nx kit
Old Oct 16, 2002 | 06:19 PM
blackbird007's Avatar
I just received my nx kit and was surprised about how short the lines from the solenoids to the nozzle is. I believe that they are only two feet long. This could be a problem, as I am going for a stealth install and will be mounting the solenoids under the battery tray. My question is, is there any harm in making new longer lines to be used to connect the solenoids to the nozzle? Thanks in advance for the help.
Old Oct 17, 2002 | 09:23 AM
NXz28's Avatar
I used the stock lenght lines, but i don't think your going to have any problems when you use longer lines
Old Oct 18, 2002 | 02:47 PM
396LT192's Avatar
I would call NX and see if they have any data from tests they may have done. The nitrous hit would be much more delayed in a system with longer lines from the solenoids to the nozzle, but as long as the lines are appropriately sized in relation to each other (i.e. Nitrous line is not shorter than the fuel line) I would think you would be OK.
CARiD
Feb 9, 2015 09:35 AM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
